Dolphin gauges water temp sensor
Yes that is the temp sender. You can get a brass bushing at most hardware stores to make it fit the larger hole in the manifold. Looks like the sender is 1/8" pipe (take with you to store). Manifold looks like 1/2" pipe, measure the hole, if it measures 5/8" it is 1/2" pipe, if it measures 1/2" then it is 3/8" pipe. Do not use teflon tape when you install the sender, it can insulate it from ground, use pipe sealant also available at the hardware store. Wire from sender goes to the S terminal on gauge. Other two wires to gauge are a ground G terminal and + power with the key on, I terminal.
I'm guessing these if they fit…
http://www.summitracing.com/parts/sum-g1483
thanks for your help guys. Would have taken me way way longer figuring this out on my own.
Rimrock F1- I think you wanna drive down to scottsdale and help me wire this thing when the time is right :-)
I do help friends all the time with wiring, fuel injection and mechanical. I think it's because I work for lunch.
I installed my dolphin temp sensor on the side of the block (where the factory sensor was installed) so I could use the port on the intake for a fan sensor switch. If you are using a mechanical cooling fan then just plug it. The one closest to your thumb (as pointed out by raytasch) look like the correct size.
Wally
Wally
Wally
Wally
I'm running an "off brand" engine in my truck and there's a port next to a soft plug where I installed my sensor (where the factory one was installed first). You should have coolant drain plugs (port plugs?) in that block (at least one on each side I believe) that will work as a place for that sensor. It was originally on the intake but as long as the coolant flows over the sensor I can't see why a coolant drain plug wouldn't work. See pic below of a removed port/drain plug on a 351, it looks like 1/4" NPT thread.
Wally
I installed my dolphin temp sensor on the side of the block (where the factory sensor was installed) so I could use the port on the intake for a fan sensor switch. If you are using a mechanical cooling fan then just plug it. The one closest to your thumb (as pointed out by raytasch) look like the correct size. Wally
Received 4,130 Likes
on
