Raptor wheels fit on Ex ?
Old 09-11-2014, 10:28 PM
HUBBSTER's Avatar
HUBBSTER
HUBBSTER is offline
Got new wheels on my Ex so thinking of putting Raptor wheels on Ex
They are 17"
Looking at some 38" Super Swampers too
Thnx
Old 09-11-2014, 11:04 PM
Technologiq's Avatar
Technologiq
Technologiq is offline
They are 17"
Thnx
Doesn't the (Raptor use 6 lug wheels?
Old 09-11-2014, 11:19 PM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
I'm only 100% sure it's 6 lug.
Old 09-12-2014, 01:35 AM
FLO98's Avatar
FLO98
FLO98 is offline
That and the weight difference, wouldn't trust them if they did fit!
Old 09-12-2014, 03:25 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
1. Raptor wheels (real ones anyways) are 6 lug and only fit a 2004-2015 F-150/Expy
2. Raptor wheels are 18"
sounds like you got doped into buying the wrong wheels, or have fake Raptors. pics?
Old 09-12-2014, 08:34 AM
Apocalypse's Avatar
Apocalypse
Don't listen to these negative Nancie's, just remove two of your wheel studs, put them on and you're golden! Might have to tack weld a bit but that's no big deal. Running some wooden 3' spacers would really set it off too
Old 09-12-2014, 08:51 AM
Krazee Matt's Avatar
Krazee Matt
Krazee Matt is offline
Apoc you've got it all wrong... You're supposed to pull ALL the studs, then weld the wheel flange directly to the hub on the rotor. Duh.
Old 09-12-2014, 09:59 AM
Apocalypse's Avatar
Apocalypse
You can't weld to wood, so if you want the 3 foot spacers you have to keep the studs... newbz, I swear.
Old 09-12-2014, 10:49 AM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
Raptor wheels are actually 17", all 3 styles of them
2010-2012 Ford F150 Raptor 17" 3831 - All Factory Wheels
That said, no way to put these on an Excursion safely.
Old 09-12-2014, 12:04 PM
USCG_PA's Avatar
USCG_PA
USCG_PA is offline
You guys are all over thinking the situation. He just need to get a set of 8 lug to 6 lug adaptors...
Old 09-12-2014, 01:04 PM
Technologiq
Why am I not surprised someone makes these. And worse - that people will buy them...
Old 09-12-2014, 01:57 PM
mecdac's Avatar
mecdac
mecdac is offline
6 on 6 there.
Old 09-12-2014, 03:09 PM
Apocalypse's Avatar
Apocalypse
Check out this link... seriously...
TRADED! 6 lug to 8 lug wheel adapters
Old 09-12-2014, 03:15 PM
Krazee Matt
Some people are more preoccupied with looking good or being unique. Even if that compromises safety in the process.
Sometimes there's no accounting for taste with some people. Ever seen a donk? Ridiculously idiotic. Ugh.
Old 09-12-2014, 10:39 PM
HUBBSTER's Avatar
HUBBSTER
HUBBSTER is offline
yes indeed 6 v 8 lug so no swap
Bought some Rockstars instead w 37" Super Swampers arriving Sept 24th
Quick Reply: Raptor wheels fit on Ex ?
