Hi all - Anyone with a clean 64-66 style side shorted out there please forward some measurements - helping another member out with his bed. I am looking for the center to center measurements of the mounting bolts front to rear (exposed bolts in bed deck) and the measurement from the forward mounting bolt to the forward inner wall of the bed. Center of bolt heads (or center of holes if the bed is off) please. Thanks a million in advance.
From 1st bolt to inner wall 2 5/16. From 1st bolt to 2nd 24 in. From 2nd to 3rd 26 5/8. Then there is the 4th bolt that is under the bed in the back rail that bolts to the frame with regular nut and bolt.
Hi, I'm the guy with the bed that 1964FORDTUF is helping. Would it be possible to get measurements from the rear end of the bed, to the rear of the wheel well, and from the inside of the front wall to the front of the wheel well, as a 2nd set of measurements to compare? Or would it be better to get those measurements to the center of the wheel well? Thank you very much for the above info.
OK from the back of the box at the floor where the tail gate closes up to, to the back of the fender well it is 23 in. From the front of the fender well to the front wall it is 22 in. The wheel well front to back is 33 3/4 in.
Thanks for all the dimensions, greatly appreciated.
