Mark's 52' F1 RestoMod Build
#122
#124
Mark
#125
#126
They also have it on eBaymotors and other sites: http://www.ebay.com/itm/Ford-F-100-/271931003704?forcerrptr=true&hash=item3f5059d338&item=271931003704
Regarding the review mirror I installed, it's BrandMotion.... link Brandmotion ? Back Up Cameras, Rearview Mirrors, Curb Sensors, Wireless Car Charging and More ? About Us they offer lots of options, HomeLink, etc
Mark
#127
#128
I received a PM asking for my 66 Impala SS build link.
Go to this link for UserID: https://www.chevytalk.org/fusionbb/i...ferral/275667/
Here is the Build link:
https://www.chevytalk.org/fusionbb/s...hp?tid/351166/
#129
Mark, that was an amazing build. Thanks for sharing. I just found it. lol
I am doing a restomod myself right now on a 52. I have the IFS, Power brake booster and Flaming River steering column in. Waiting on the crate motor and gathering other parts up.
A couple questions if you remember. You said the radiator fit the old bracket and mounts. Where did you get the radiator? What engine mounts did you use? (I am installing a 351W also). Thanks in advance. Tom
#130
Hi Tom. Here's some info I hope helps you.
First, the fitted radiator. I bought from SummitRacing.... they have several to pick from.... try this link; https://www.summitracing.com/search/...num%20radiator
Second, the engine mounts. Since I used a purpose built new box frame, they take any standard Ford SB engine mount.... again, I bought Poly mounts from Summit. If you're using the original Ford frame, I'm sure someone make a conversion from orig frame to a SBF engine. Certainly, someone on this forum steer you in the right direction. If you're handy at fabrication, this would be a good project.
Good luck, Mark (if you need anything else, just let me know!)
#131
#134
My latest Truck build... a '35 Ford truck hot rod
Here's the link to my '35 Ford truck hot rod if anyone is interested.
Mark
https://thefactoryfiveforum.com/show...w-Gen-3-Coyote
Mark
tonyguns
269
12-12-2023 12:35 PM
Rimrock F1
240
02-23-2022 09:18 AM
bhalemail
01-04-2021 09:22 PM
