fuel selector valve hoses for a 6/77 F-250 4x4
during my process of going thru the fuel system in my truck and replacing ALL the rubber fuel lines/vapor lines, my 3 fuel selector valve hoses are extremely brittle. Does anybody know where i can get new ones ? LMC doesnt show any. thanks, Chris
The Chinese $*** is just that, it doesn't last.
Common replacement fuel hose from the AP store should work fine (3/8" most likely but check). Anything sold today should be compatible with alcohol. "Fuel injection" rated hose may be better but not necessary.
FWIW the aux tank hoses on my truck failed first. They got soft as cellophane when wet with fuel and sucked shut.
If you're concerned about the hoses collapsing because of the bends, what I've done in the past is either like you said, bend a steel tube and use short pieces of hose for couplings or I've also taken a long coil spring, something like a screen door spring, and put it in the hose. This will keep the hose from collapsing when you bend it.
Hardlanding
12-15-2015 09:48 AM
AXracer
08-18-2014 09:05 PM
skuteman
07-11-2004 11:31 PM
