95 F150 4x4 6L 5sp ugly but mechanically good $700.
Year: 1995
Make: Ford
Model: F-150
Price: $700
Mileage: 250000
Color: white
Private or Dealer Listing: Private Listing
Location (State): AR
Transmission: Manual
Drivetrain: 4WD & AWD
Color: White
Engine: 6 L
This is a truck used as a farm truck. It has a 300 efi 6 cylinder engine, 5 speed trans, 4 wheel drive, manual Warn hubs.
The Good: This is a good off road truck, it will pull strong, cranks and runs good, no oil leaks It is also used on road in 2WD to haul hay & feed, gets around 15 mpg . Manual warn hubs, newer clutch slave cylinder, newer clutch, newer oil pan gasket, newer battery, new mud tires on back, fair mud tires on front (all 33 x 10s), newer radiator, new clutch linkage connector. Air conditioner works great gets very cold. All gauges work, The truck has dual gas tanks but we only use the rear, outside manual mirrors, all lights work, new right headlight, good bed and tailgate, split exhaust for duals, bumper ball 2" hitch.
The Bad: Hit a stump and destroyed front bumper, wielded on a piece of angle iron to replace. Bent hood right side hinge, put hole in radiator (replaced), binged up grill and trim. needs one rear wheel brake cylinder, clutch linkage needs adjustment, radio out (have two used ones but need to be installed), missing left side window crank, needs door hinge pin replaced (have part included). door panel has been removed but have it to include.
The Ugly: the interior, cracked dash pad, needs seat cover (seat is good just fabric worn out), inside mirror missing, wind vent missing handle, drivers door handle and window roller missing, key broken off in ignition (starts with screw driver), (door locks with key works), windshield cracked.
The truck has always been serviced and maintained.
JBCustomZZ
03-24-2006 10:16 AM
