Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
C Series 389 flywheel ring gear question
Old 09-01-2014, 10:09 AM
Fireman32653's Avatar
Fireman32653
Fireman32653 is offline
I have a 76 C800 with a 389. The starter was grinding and when I replaced it I noticed a group of bad teeth. I got it started and home but now I need to replace the ring gear or the whole flywheel. Does anybody know which ring gears/flywheels interchange?? I've seen 184 and 188 teeth as options as well as 11 and 15 inch flywheels. There seem to be lots of information but no clear interchange. I'm trying to order the replacement ahead of pulling it apart.
Old 09-01-2014, 07:47 PM
dmanlyr's Avatar
dmanlyr
dmanlyr is offline
Check this link out, it seems that all the FT motors used the same ring gear. However there were several different manual clutch flywheel assemblies that were different size, but all it seems used the same size / tooth count ring gear.
https://www.ford-trucks.com/forums/1...rt-number.html
There are even sources listed for the part......
David
Old 09-04-2014, 08:58 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
I've seen 184 and 188 teeth as well as 11 and 15 inch flywheels.
184 tooth ring gear was only used with FE engines (1965/76 F100/350 & 1958/71 cars), there are no such things as FT 11 or 15" flywheels.
Your C800 should have a 13" clutch.
C4TZ-6375-D .. M/T Flywheel - 188 tooth ring gear / Marked: C4TE-6380-J or D2TE-6380-CA / Obsolete
1964/78 FT engine applications: 330 2V Heavy Duty / 359/361 / 389/391 // NOT used with 330 2V Medium Duty engine!
The 359 & 389 were FoMoCo's confusing engine sizes for 1973/78 detuned for smog 361's & 391's.
The ring gear can be replaced by itself.
C4TZ-6384-A .. Flywheel Ring Gear - 188 teeth / Obsolete
Applications: 1964/78 ALL FT engines.
texczech
Large Truck
16
12-06-2021 12:04 PM
GJCAT
Large Truck
08-17-2014 04:49 AM
624WD
09-27-2013 04:33 PM
northnoob
05-15-2013 09:38 PM
Aune163rd
16
05-06-2011 09:43 AM
Quick Reply: C Series 389 flywheel ring gear question
