Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Our 83' F700
Old 09-25-2013, 04:05 AM
m350's Avatar
m350
m350 is offline
Our 83' F700
Hey all, well we Just picked up a F700, 370 4V, 5 speed, got her home last night, is a nice driving truck, steers straight down the road, Brakes work Good, got her up to 60 mph, still gaining, truck/cab has hardly any rust/rot on it, and is in nice condition, need to fix some stuff not working like, dash lights, heater, wiper blades, couple lights, PTO is noisy (rattles some), got a knapheide 14' Flat Bed on it, no hoist, not sure if going to use this Flat Bed or install a 10' Dump body with tailgate. Will have my son post some pics soon !,,Mark
Old 09-25-2013, 07:41 AM
CLR f-150's Avatar
CLR f-150
CLR f-150 is offline
Ok guys here are some pics hope you like them
Old 09-26-2013, 04:45 PM
Pete Kildow's Avatar
Pete Kildow
Pete Kildow is offline
Clean looking truck, would be nice with a dump on it for sure. Thought about trying to replace the gooseneck bed on mine with a 9ft dump bed. But being I will use it for pulling our 41ft camper don't think I will do that.
Pete
Old 09-29-2013, 05:40 AM
m350's Avatar
m350
m350 is offline
Pulling the flatbed off today, looking for a dump body, a 10' 4-6 yard would fit nicely, but so far have only found 10' 5-7 yard bodys, 5-7 will be ok really just for small firewood deliveries anyway , but a 5-7 could easily overload this truck with dirt on it, not a good thing !!
The truck is very clean for 30 yrs old, I have been all over it, only has 3 - I/2 dollar size, rot holes in drivers floor, and a spot with 3 pencil size holes, the drivers door has a 8" x 1/2" rot on the very bottom(underside) of door, going to treat it, keep rot from spreading and leave it alone.
Old 09-29-2013, 09:06 AM
Pete Kildow
Bigger bed would work just fine. Just don't fill it up and your good to go. Plus if your hauling firewood or something that has bulk but not as much weight it will haul more there.
But just remember to not fill the 5 to 7 yd bed full of rock or dirt. Shoot even in our 16ft dump beds we used to run, some products we could not fill the bed or be way over our 74,000 lb gross on a Tri-axle.
Pete
Old 09-29-2013, 08:45 PM
stuart9534's Avatar
stuart9534
stuart9534 is offline
Nice truck! I have been looking for one that nice for a good while to pull my car trailers.
Old 10-01-2013, 04:44 AM
m350's Avatar
m350
m350 is offline
Ok we took the flat Bed off the F700, that is one rugged flatbed(Heavy), a day or two Before we took the bed off,, the truck seemed to suddenly loose all it's vacum, for the Brakes, Buzzer comes on briefly while steering, seems to be the Brake Booster check valve, here hissing sound when truck shuts off, have one on order.
Also when truck was warm, running kind of rough, rich gas smell, headache making smell, cant seem to find carb adjustment (rich/lean mixture screws), plus seems the EGR plate is blown out, exhaust leak, so ordered a Holley 600 manual choke and a 1" spacer setup, I know no Govenor setup on this carb, should help it run better, will see how it turns out.
Old 10-03-2013, 10:41 PM
m350's Avatar
m350
m350 is offline
The Vacum Booster Check valve arrived today, my son removed the old one(just fell apart) installed New Check valve, started truck, ahhh vacuum Gauge is where it should be, No Buzzer, Nice when it's just a $30 dollar part.
Earlier this morning, at 7:30 am off we went to pickup the 12' Rugby Dump Body I found on Craigslist, Cab protector, 12" fold down sides, Hoist and sub-frame, (Need to find a tailgate)In decent shape, Got it for $950, so parts are coming together for the F700.
After re-measuring the truck cab to axle and beyond a 10' Dump Body was not right for the truck, had to move the axle, lots of drilling, cut redo the drive shaft etc, the 12 Body will be easier to install.
Old 10-12-2013, 08:37 PM
m350's Avatar
m350
m350 is offline
We got the 12' Rugby Dump body Installed, dumped it with the electric hoist worked but kind of slow, tried the PTO that was on the truck, very Noisy, emailed Chelsea with the #s, wrong PTO or gear for a Clark 285 trans, anyone have a Chelsea PTO #
100XRBS-XW3A Right side (is a 27 T gear)for a Clark 285 tranny 1968 or newer ? older then 68' is different !
100XRDS-XW3A Is the Chelsea PTO on the truck(is a 28 T gear) for a Warner tranny
This is the info from Chelsea!,,Mark
Old 08-29-2014, 05:13 AM
CLR f-150's Avatar
CLR f-150
Guess my dad has been slacking on the updates on the f700, after many months of messing with the brakes on it we finally got them working right, all new wheel cylinders, brake booster and brake lines they work sweet. Now we got sides made for the dump bed and can start getting that together finally. After buying a new pto driven pump and a tank it dumps really nice, heres some more pics of it any questions ask my father
Old 08-29-2014, 01:51 PM
m350's Avatar
m350
m350 is offline
Yep as of Monday 8/25/14 the dump body and tailgate have been painted same color as the wheels, Rustoleum Hammerd Silver, and this Laborday weekend hoping to paint the cab Rustoleum Sail Blue with a coat of Rustoleum Automotive Clearcoat applied after, also have a Sun Visor for it to be painted the same time.
The Brakes were somewhat of a challenge while it had new brake shoes, and someone had been in there Anti-seize on many items, the wheel cylinders were seeping , so we changed all 8 of them, 2 on each wheel, then also replaced every brakeline with 1/4" Ni/Copper lines, and the flex lines, finaly the Brakes work sweet, Now paint, lights, new plugs, change the oil, safety items to check out, and then see about the registration.
PS the Hoist is painted sail Blue color!
Old 08-29-2014, 08:46 PM
Pete Kildow
Sounds like you have done a lot of work for sure. If I still have my F800 next spring. I'm thinking hard about putting a dump bed on it. We can always use a dump truck around the farm. Wonder how a dump bed would work on my truck and leave the sleeper on it also??
Also been thinking about adding a F350 dually bed to it and making a toy out of it.
Pete
Old 08-30-2014, 05:30 AM
m350's Avatar
m350
m350 is offline
Yes we have some time in working on the F-700, but many of the days were waiting for Napa to get in wheel cylinders, then they would be the wrong ones, or, Get this, a Old Junk wheel cylinder, sent to Napa from there warehouse in a sealed box!!
Yes after that we checked each item before we left the store !
Also many days waiting for garage space to be available to work on it, also purchased a 35 Ton air jack from Northern Tool, sure helps to Jack the Truck up easier
I purchased the Eastwood Brake Flaring Tool kit from Amazon, That sure made the Brake line replacement go faster, easier, would recommend it to anyone, about $ 50 cheaper at Amazon then Ebay .
I purchased the truck September 2013, here it is about September 2014, Not yet on the Road, But Making Progress.-- Mark
PS, The tailgate(Rugby body did not have one) is From a Good Friend of mine who Passed away in November 2013(RIP Dominic) Tailgate(in Good Condition) was from an Old F-600 AWD he had restored in the early 80's, that has since been put out to pasture, sitting as a rusted out parts truck, so In sense will keep a Part of him memorialized !
Old 08-31-2014, 07:38 PM
m350's Avatar
m350
m350 is offline
So today Sunday 8/31/14,Have the F-700 cab close to being painted tomorrow, mirror's are off, cab lights, headlights, Hood, Grill , and front signal's are all off the truck, even the Cowl grill, front Bumper and windshield trim are off, back window, windshield are masked off, had some slight body work to touchup, a lot of scuffing, and someone's previous runs in the Tan Paint to sand out Hopefully by Noon sept 1st she will be Sail Blue. Try to get some pics off it up.---Mark
Old 08-31-2014, 07:51 PM
CLR f-150's Avatar
CLR f-150
Quick Reply: Our 83' F700
