Sponsored by: Kumho
Wheel Fitment
Old Jul 13, 2003 | 05:21 PM
natewoz's Avatar
natewoz
Wheel Fitment
Has anyone tried to put 16x7 94-01 dodge ram wheels on a 92-96 f150 4x4? I currently have the 10 hole 15x7.5 aluminum wheels that I beleive have 4.25" of backspacing. The ram wheels have 5" of backspace. With a 3" body lift and 2.5" suspension lift I am considering using the ram wheels with 255/85r16 Dunlop Mud Rovers.
Old Jul 13, 2003 | 05:31 PM
mrwizard's Avatar
mrwizard
Wheel Fitment
Bolt patterns are the same, but more backspacing would cause tire rub problems.
Old Jul 13, 2003 | 05:47 PM
natewoz's Avatar
natewoz
Wheel Fitment
If the backspace was a lot different I would have never asked. It just seems like I could get away with an extra .750". Thats all.
Old Jul 13, 2003 | 07:01 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Wheel Fitment
Nate, I'm in the process of installing a set of the Ford 7.5's on my Bronco. By my best measurments, the backspacing is 4 1/8". The critical dimension for you will be the distance between the wheel rim and the tie rod end. You might get under the truck, and measure it with the 7.5's on. You will need at least an inch clearance for the Dodge's to fit.
I don't think you will have that much clearance on your 4x4. If it's almost enough, you might be able to grind a little off the tie rod end......?
hav24wheel
Dec 1, 2013 12:15 PM
train2
Mar 13, 2012 06:48 AM
j7angus
Jun 13, 2011 11:54 AM
fjatheart
Feb 5, 2011 11:41 AM
Ford4dog
Jul 13, 2008 07:34 PM
