Aerostar Ford Aerostar
Air Intake Tube rubber Seals
Old 09-09-2014, 08:16 AM
Jose A.'s Avatar
Jose A.
Jose A. is offline
trying to locate the two rubber seals located at each end of the plastic Air Intake Tube or Duct;
one side of the Tube or Duct connects to the aluminum intake at the engine, and the other side of the tube or duct connects to the Air Filter Box.
There are two stainless steel Clamps. Under each clamp there is a rubber Seal or Gasket.
my seals or gaskets are becoming gooey, falling apart. Need to replace them.
Any help appreciated. My engine is a 4.0 liter. (the picture below shows the 3.0 liter duct but the seals are the same).
Old 09-09-2014, 11:42 AM
87&97Aerostrar's Avatar
87&97Aerostrar
87&97Aerostrar is offline
I never really inspected it that closely, but I always thought that it was all one piece. If there's an Aerostar in your local pull-a-part that entire tube is probably just laying there close by.
Old 09-09-2014, 01:40 PM
Jose A.'s Avatar
Jose A.
Jose A. is offline
thanks, there are two rubber seals, one at each end of the air intake duct, you can see one in the following picture
Old 09-09-2014, 02:09 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
If it's no longer available from Ford, I would check the boneyards near you. In fact, now that you mentioned it, I think I'll do that this weekend.
Old 09-09-2014, 03:59 PM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
I would also check Rangers, probably the same part.
Aeros are rare as Mercury pickups in the junke yards here, exported to China.
Old 09-10-2014, 01:41 AM
Jose A.'s Avatar
Jose A.
Jose A. is offline
yes, same seal is used on the Ranger, but also obsolete.
Old 09-10-2014, 04:48 AM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
try this guy
retired Fords parts guy is FTE member, best in the industry
can find you anything Ford. has access to the dealer network search and Fords old parts books.
Number Dummy
Ford Truck Enthusiasts Forums - View Profile: NumberDummy
Old 09-10-2014, 05:20 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1990/2001 Ford Light Truck Parts Catalog (Illustration section 96, page 20) does not show any individual seals, just the hose, which is Aerostar only.
F69Z-9B659-AA .. Engine Air Cleaner Outlet Tube Assy / Obsolete / Last MSRP: $59.47 - Dealer net cost: $35.68.
Applications: 1996/97 Aerostar 4.0L / No Ford dealer or obsolete parts vendor has any.
Old 09-11-2014, 01:26 AM
Jose A.'s Avatar
Jose A.
Jose A. is offline
Thank you for the help.
Old 09-11-2014, 05:51 PM
93nighthawk's Avatar
93nighthawk
93nighthawk is offline
Both the early 90s Explorer and Aero list F3TZ 9E926-AA for a Throttle body and FO7Z-12B579-AARM for MAFs so an Explorer hose rubber ends off of a F47Z 9B659-A "should in theory work"
A little research in the junkyard before buying new might be worth it sense the hose lists for $155.80.
linus72
07-16-2012 11:39 AM
Corner Gas
26
05-27-2009 09:34 AM
SteelHorse08
2004 - 2008 F150
02-28-2008 08:45 PM
Lone_Ranger01
1983 - 2012 Ranger & B-Series
02-09-2004 01:28 PM
Quick Reply: Air Intake Tube rubber Seals
