no fuel
Old 09-02-2014, 07:30 PM
tfink3's Avatar
tfink3
tfink3 is offline
no fuel
My truck quit running while driving the other day. It has done this before, but has always restarted. It just quit running and wouldn't restart. It has fuel, and the fuel filter has been changed. I changed the fuel pump twice, thinking I got a bad one from the parts store. I changed the fuel pump relay and fuse, and checked the fuel shutoff switch. I can take the line off the back of the fuel filter, the one that goes to the tank, and turn the key on, and no fuel comes out at all. I can even turn the engine over, and I still get no fuel. I tried to spray some carb cleaner in the intake, and still get nothing. What are the chances of the fuel shutoff switch being bad? Any other help would be awesome. Oh, it is a 1997 Ford F-150 4.6L V8 4x4 manual transmission. It is a supercab.
Old 09-02-2014, 08:25 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Much of the description suggest the PCM is losing power.
Reseat or swap the PCM relay and fuse.
See what that does for you.
Spraying starter fluid and getting no response means no spark.
No fuel pump operation means no power or ground to the pump.
Key on and no pump or cranking and no pump also can mean no ground to the pump via the PCM. The pump circuit has to get it's operating ground from the PCM.
Seams it all ties together.
Good luck.
Old 09-02-2014, 08:58 PM
F91's Avatar
F91
F91 is offline
You said you sprayed carb cleaner into the intake, hope you meant starting fluid as the cleaner ain't gonna fire.
Old 09-02-2014, 10:08 PM
tfink3's Avatar
tfink3
tfink3 is offline
The pcm, is that the big plugs on the firewall passenger side under the hood?
antiqueynot
1983 - 2012 Ranger & B-Series
91
08-25-2023 05:06 PM
Critterhunter
06-17-2015 05:11 PM
aquaj7
1997-2006 Expedition & Navigator
01-10-2015 09:24 PM
Stuart Grantham
07-02-2014 08:22 PM
JoePeeper
10-23-2013 04:24 PM
Quick Reply: no fuel
