technical thoughts about wmo and timing, surging, and drivability concerns
I've been running wmo for quite some time now, and have some thoughts bouncing around my head about it.
1) I've heard multiple guys around here acknowledge the surging that seems to just happen for us oil burners. I've been analyzing it every time I drive and think I have a decent understanding of what's actually happening. I used to think I was suffering from fuel starvation, but now I don't think that's the case most of the time.
2) my current theory is that all this surging and variations in performance is caused by improper timing control. I notice what seems to be the timing going far advanced, making excessive clatter and more power than normal. I used to blame this on air intrusion, but now I think otherwise. Other moments on the road I seem to lose power but not completely. I believe this is the timing going retarded. In these events I have no clatter at all, it sounds like a gas motor, and I can maintain speed but not up hills, it's gutless at these times.
And it goes back and forth between these two conditions quickly, too quickly for it to be fuel starvation or air intrusion.
The prevalence of this issue directly correlates to the percentage of used oil in my fuel, with it performing normally on pump fuel.
So all that said, I'm thinking that the problem is clearly that the timing controls inside the injection pump are responding randomly when the fuel is too thick.
Does anyone have any input on my theories?
Obviously the simple response is to adjust my fuel mix to a level that works right, which I'm running around 75% oil in one tank and mostly pump fuel in the other.
I have a ferett timing meter and set it properly when I installed the pump, so I know my base settings are correct.
I have no personal experience yet, as I am still juggling with converting my 94. 7.3 into electric fuel. I have also been reading up on converting my second tank into being able to handle straight bio once I do.
But, my buddy has used WMO before, he said his power issues were related to fuel temps pre-injector and the size of the pre and post fuel filters getting clogged up. Do you use a heated fuel filter element? Also, are your injectors rated to run bio without issues?
That being said, I wonder... If you're using WMO, why not add a few percent gasoline to the mix? It will reduce the viscosity signifigantly(according to one page I read, each 10% gas you add reduces the viscosity by 50%), and considering all of the engine oil, I don't think you need to worry about lubricity...
I've also talked with a guy who ran a WVO/gas mix in his old car; I forget the exact engine, but it was up in the 400-500K range with most of that on the mix -- he just mixed the stuff up, let it settle for a long time, filtered off the top and ran it.
David85
05-31-2008 07:38 PM
loneleader
22
02-05-2005 11:45 AM
