Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Window problems please help!
Old Aug 30, 2014 | 08:33 PM
Truck Guy99's Avatar
Truck Guy99
2008 Ford escape. Parked it last night with all windows up. Walked out to it today and the back left window was partially down. Tried rolling up and down but it won't move without help and it won't stay up. I hear the motor spinning but no movement on the window. It belongs to a family member and it's her daily driver. How do i fix it and is something broken?
Old Sep 1, 2014 | 09:08 PM
Torky2's Avatar
Torky2
Poke around at rockauto.com to see what a window regulator assembly with motor looks like for the 2008 Escape. They have a left rear Motorcraft rebuilt, it is miss-filed under something like "power window motor gear".
The motor winds/unwinds cable onto a spool. So if it winds on one side (the pulling side), it is unwinding on the other side (the slack side). This moves the trolley up and down the track depending on which direction the motor turns. The window glass is attached to the trolley.
This idea is used for most cars these days. I have never opened up a door panel yet on an Escape (and hope never to have to ). But have replaced them on other. What I learned was... not to attempt to replace only the motor on a cable-operated window regulator! Instead, to just to go ahead and replace the whole regulator assembly with motor as a unit. Not only is trying to handle the cable in a motor-only replacement attempt a real bear, often the cable is kinked, or a part of the regulator wore through, which meant the whole thing needed to be replaced anyway.
Those are my experiences, anyway.
I would take the door panel off, and take a look in there with a good LED flashlight. You will probably find... it's broke.
Old Sep 1, 2014 | 10:01 PM
Truck Guy99
Thanks. I figured I'd replace the regulator anyway. So I pulled the door panel and one of the cables was laying in the bottom of the door. The blue part with the spring around it is busted too
I think I'm gonna order this for it.
Amazon.com: Motorcraft WLRA-109 Power Window Motor: Automotive Amazon.com: Motorcraft WLRA-109 Power Window Motor: Automotive
billybobzia
1997 - 2003 F150
May 30, 2012 02:39 PM
fordtrkman
2004 - 2008 F150
Dec 2, 2009 11:52 AM
rangerbob406
Apr 25, 2008 11:16 AM
greyfox503
Feb 17, 2008 09:55 AM
pherve
Jun 7, 2007 04:21 PM
