Various 73-79 Ford Truck Parts
Category: Accessories
Price: $20
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Prelude
Item Condition: WV
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck
New Passenger Side Hedman Header 351m/400 Exhaust Gasket
Square Gas Tank Door
351m/400 Water Pump Pulley
351m/400 Coil
Ignition Module
Blower Motor
73 - 77 Amber Front Turn Signal/Parking Lights
Front Side Marker Lights
Circular Headlights and Trim Rings
Square Headlights and Trim Rings
Starter Solenoid
Wiper Switch
Ignition Switch
Headlight Switch
Brights Switch
Drivers and Passenger Window Cranks
67-72 slim Drivers side mirror
Passenger Inner Door Handle
Drivers and Passenger Outer Door Handles
Gauge Cluster With Oil pressure gage
New Vent Window Seal
Battery Cable
In Cab Fuel Tank Gas Caps
Blower Motor
New Passenger and Drivers Side Lower Front Door Post Sheet Metal
New Passenger Side Side Lower Rear Door Post Sheet Metal
Ranger Woodgrain Glove Box Cover
80s - 90 Ford Factory Radio
How about a exhaust manifold plenum heater valve for my F150 300\6 of 78 vintage? And tan door panels too, maybe... the PO made wooden ones that do the job but, you know. I get a lot of grief bout em! And you wouldn't have the top bracket to hold on to the heat shroud for the intake heat pipe? That'd be awesome if you do! 54896
Ford247, I looked at these a bit closer and they are in pretty rough shape, probably better off in the scrap pile.
borland
34
01-07-2015 10:15 PM
Shiro
23
08-14-2014 05:50 PM
mshumack
26
03-21-2006 07:59 AM
eek1127
01-03-2004 09:20 AM
