Dad and Son Motor Build
Old 08-27-2014, 11:19 PM
EstesTruck's Avatar
EstesTruck
EstesTruck is offline
I know this probably isn't the place for the intro, but it's the only place in this forum I will be most likely. Anyway, I just joined after reading a plethora of info about the FE motor.
My dad has always wanted a 390, since he was a young man. He has a 70 model ford F-100 with a 360 in it, BUT we just aquired a 390 from and old guy he knows for $300. Everything except the Flywheel and Carb. We have both built engines for a long time. But he's always been into Fords and Tractors, and I'm a Chevy guy. Well, we are coming together on this build and I'm really looking forward to it.
From what I've read we have a good starting point. The block has numerous stamps which is normal apparently. D3TE is on the block along with 4C26 (which I figured out means 26th of March 74') Correct me if I'm wrong, but the D3TE is a heavy duty block used in trucks. It also has an X cast into the side, and a mirrored 105.
We haven't pulled the Crank yet, but the Main Caps say D2TE. The crank isn't in a position that we can see the numbers and it's locked up so no moving it. Soon enough though.
Anyway, sorry for the long post, but I'd figure I'd get some info out there and see what people say about the engine. I'm up for any advice, red flags, anything too look for. We don't completely have a game plan yet. We'll probably get more of a game plan after talking with some people on here.
Old 08-28-2014, 07:18 AM
69cj's Avatar
69cj
69cj is offline
If it's locked up fill the cylinders with penetrating oil at least for a few hours or overnight before trying to pop the pistons out. Might save a cylinder wall that way.
Old 08-28-2014, 01:53 PM
EstesTruck's Avatar
EstesTruck
Yessir, will definitly do that. We will probably be boring it out though. The "loose plans" that we have so far are a bore (not sure on how much yet) and full bearing replacement and having everything trued.
I am looking to get a higher compression, yet use the crank and rods that are in the truck. What would be the best way to do this? Deck the block, use high rise pistions, Both?? I don't want to go over 10:1 but would like to see no less that 9.8:1
Old 08-28-2014, 05:45 PM
69cj's Avatar
69cj
69cj is offline
If the blocks good go with pistons. Once the block is decked you can't go back. I'm running 91 octane on a 10.6 compression 428 cj. You just have to watch the timing curve.
Old 08-29-2014, 05:57 AM
Hypoid's Avatar
Hypoid
Hypoid is offline
You might look into replacing those Connecting rods. Side by side, the 390 rod makes the 360 rod look spindly. Another thing to keep in mind, is that the 360 rod is longer.
Old 08-29-2014, 10:06 PM
EstesTruck's Avatar
EstesTruck
Yea, weve been told to put 360 rods in it. Any idea whT the HP limitations are on em?
Old 08-29-2014, 10:17 PM
tbm3fan's Avatar
tbm3fan
tbm3fan is offline
Excuse me? Told to put 360 rods into a 390 build?
Old 08-30-2014, 06:32 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Subscribed. 360 rods do not a 390 make.
Old 08-30-2014, 08:26 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,592 Likes on 1,297 Posts
360 rods in a 390....Use the 410 piston. Maybe.
1.89 + 6.64 + 1.678 = 10.108 into a 10.17 block. Other than the fact those rods are not as strong as the shorter ones, it might work. Unless I am missing something obvious.
For a really cheap build, get a pickup 390, and you already have the 410 piston and 390 crank.
Serving suggestion......
edit:
I search a bit more and found this:
http://www.network54.com/Forum/74182...uild%26quot%3B
Scroll down to the post by TorinoBP88.
More of the same:
http://www.network54.com/Forum/21142...+rods+in+a+390
Old 08-31-2014, 11:29 AM
Hypoid's Avatar
Hypoid
Hypoid is offline
I had to do some searching, Ceetwarrior had 360 rods in his 390. This was due to some hack work by a shop that had no experience with FEs.
As noted, you'll need some low compression pistons to keep the slugs below deck.
Somebody on this board took the time to do the math for Ceetwarrior, I think the post is quote worthy: https://www.ford-trucks.com/forums/1...l#post10028849
Old 08-31-2014, 01:00 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
If you have a low compression 390 and an extra set of 360 rods laying around, putting the360 rods in will bump the compression up a fair bit for cheap.
Old 09-01-2014, 09:13 PM
EstesTruck's Avatar
EstesTruck
Damn, been a few days since I looked on here and got some good responses. You know, I may have miss spoke. Maybe it was put 390 rods and crank with 360 pistons. Hell, I don't know, we were told something!! Maybe I'll just go with the pistons and keep the rods and crank.
Old 09-01-2014, 10:46 PM
85e150's Avatar
85e150
85e150 is offline
360 pistons are one of two flavors. A flat top with valve reliefs, or a slight dish top with valve reliefs. These pistons are the same specs, if not the same exact parts, as the pistons installed in car 390s in the late '60s. The flat top piston was the "Premium Fuel" 4bbl motor with 10.5 CR. The dish job was the "Regular Fuel" 2bbl motor with a 9.5 CR. (Some Mercury 2bbl motors were 10.5)
If your 360 pistons are in spec wear wise, you can reuse them on top of a 390 crank and rods and have 9.5ish or 10.5ish compression, depending on your heads.
This is better than the 410/390 pickup piston on a 360 rod.
Old 09-02-2014, 02:21 PM
EstesTruck's Avatar
EstesTruck
I know that everyone has there aftermarket preference. But lets say I want to bore it and use bigger pistons. Anyone have some good brands they prefer that aren't insane expensive. I've always preferred Diamond... but this is not a crazy boosted motor build. I think I can get away with a milder brand.
Old 09-02-2014, 03:39 PM
85e150's Avatar
85e150
85e150 is offline
You only bore if you need to. Thick cylinder walls are more important than .030 or .060 more bore.
Lots to choose from:
http://www.summitracing.com/search/m...e?N=4294914196
Decide on what type and remember you want a piston compression height of about 1.78" if you want 9 to 10 =/- compression.
Probe Industries - High Quality Forged Pistons, Shaft Rockers, Main Girdles, Stud Girdles, Engine Kits, Crankshafts and Connecting Rods for Buick, Chevy, Ford, Chrysler, Pontiac, Oldsmobile and Sport Compact Applications. - 866-718-6267
Quick Reply: Dad and Son Motor Build
