IPR/ICP? NO START SITUATION....
If I turn the key to the on position it just pumps air..... the only way I can get fuel into my fuel bowl is by removing the filter and putting my finger over the FPR (at least I think that is what the top port is on the drivers side of the bowl)....after I do this for a few seconds, fuel comes through the inlet as it should.....I put the fuel filter back in and crank, the bowl drains, no start and and I am back to square one, pumping air....
Does this make any sense to anyone?
The more I work on this, I kind of think the lift pump may be bad. Here is where I am at:
Batteries are charged and crank speed is good. I tried cranking without the ICP hooked up, even though I don't think that is the case.
I have the fuel filter out of the bowl, fuel is just above the inlet. The last time I cycle the key, I was getting no fuel and very little air and it sounded kind of weak. I got underneath as it was trying to pump and I tapped on the lift pump and it sounded like it picked up speed and got louder. I don't have any experience with the lift pump, but I do run VEG through it....I am thinking this may be the culprit.
I am going to fill the diesel tank up just to rule out the not getting any fuel from the tank before I replace the lift pump.....
any thoughts?
any thoughts?
katman104
03-21-2018 07:40 AM
Ray Vaughn
32
06-12-2013 09:57 AM
