Do 1955 Ford Generators look different than 1956?
Old 08-27-2014, 11:52 AM
Jag Red 54's Avatar
Jag Red 54
Jag Red 54 is offline
My voltage regulator on my 55 Ford malfunctioned and drained my 6-volt battery. I replaced the voltage regulator and charged the battery. When I started up the 272, the voltage coming in from the generator was barely 7.0 volts. This number had always been in the neighborhood of 8.1v. I tried polarizing the generator, but nothing changed. I theorized that the bad regulator had let the battery discharge through the generator all night and burned the brushes. I took it to the local auto electric repair in Sacramento. Sammi called me the next day and said that when he opened up the generator, it looked like it was 12 volt. I've had that generator for twenty years and it has always put out a little over 8 volts. My question is: Does the inside of a 6v Ford generator look different than a 12v? Or, is my guy confused because Chxxy generators look different? Jag
Old 08-27-2014, 08:55 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
My memory is that the armatures are identical and the field coils are different. So no, they are not technically visually different. An armature from a 12 volt generator or an armature from a 6 volt generator will do an identical job.
That said, Ford changed the rear bushing to a rear bearing somewhere around the time they switch to 12 volt. I think the bushing to bearing change happened a year or two before 56, but I'm not 100% sure. So yes, the later generators do look different from the earlier. However, this does not distinguish a 6V from a 12V generator.
Old 08-27-2014, 09:43 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
And just to confirm that, I have a 6 volt generator on my 51 from what I assume is a later year truck. It has the rear bearing instead of a bushing.
Old 08-28-2014, 10:39 AM
Jag Red 54's Avatar
Jag Red 54
Thanks guys, I had no idea that Ford would have used a bushing instead of a bearing. Seams like guaranteed replacement. I got the gen reinstalled and it's putting out 8.0v Jag
1950FordF1
12-09-2015 06:53 PM
rswhitmore
08-23-2015 08:59 PM
chris1911
Electrical Systems/Wiring
02-24-2014 05:04 PM
cw2
04-30-2005 09:06 AM
SCFLATHEAD
08-24-2004 06:36 PM
Quick Reply: Do 1955 Ford Generators look different than 1956?
