1998 Explorer - Won't Start When Theft Light Flashes Rapidly
I recently developed a problem with starting the vehicle. It won't start when when the THEFT light flashes very rapidly after I turn the ignition key. I can get it to start by moving the shift lever (automatic) down to 1st and back up to park. However, sometimes it takes several tries before it will start.
It's an intermittent problem. Happens about once every 10 starts or so, and seems to be getting more frequent with time. All other times when the THEFT light is normal, it starts just fine.
Suggestions about the cause and a fix would be appreciated!
Your '98 Explorer is a column shift, correct (versus console shift on the floor)? The flashing Theft light indicates the Passive Anti-Theft System (PATS) is not recognizing the key. There's a transponder in the key, and the transponder is energized by an antenna loop around the ignition key cylinder switch. Since moving the shift lever seems to have an effect, I'd suspect there's an issue with the PATS antenna loop. It could be the connection at the key loop or an issue with one of the connections further down the steering column.
-Rod
-Rod
similar problem on my '98 explorer
Mine seems related to the tilting of the steering wheel. When wheel is flipped up, anti theft light and no start. Column kept all the way down, never a problem. I was afraid to have it looked at for cost reasons. And afraid to tackle it myself. I just keep the wheel down, a few years now.
I keep it down, all the time. I used to be in the habit of always flipping the wheel up, now I'm in the habit of always keeping it down. Whenever it goes into a shop, I place a note on the wheel," do not tilt" LOL. It really works as an anti theft device now, flip the wheel up and it won't start.
greasy hands
09-13-2016 01:19 PM
trun10tion
1997-2006 Expedition & Navigator
04-07-2015 10:02 PM
FordF25087
02-23-2015 08:28 AM
only1bigdaddyo
11-10-2014 10:34 PM
