2003 6.0 hard start hot
Just bought an 03 6.0. Has 135,000 miles. When I got it it would hesitate and be low on power when driving. Truck was also starting very hard when warm. Would take 3-4 attempts to start. Removed icp and powered IPR. Found air leaking out of filter housing. HPOP was leaking.
Replaced hpop, oil cooler, and deleted egr cooler. Rechecked for air leaks and did not hear anymore. Put a few hundred miles on truck and it starts better than before and has full power now.
Problem is when warm after sitting for 15 minutes to an hour it takes a few seconds to start and than sounds like it's not running on all 8 cylinders for a couple more seconds. Does not set and codes but need to figure out why it does it. Could glow plugs cause this?
ficm voltage is 48.2 volts when starting
Icp pressure is at 1100 when it happens
Ipr is mid 30%
Jacked the front of the truck up and let it sit for an hour after it was hot. Truck wouldn't start. Pulled the oil filter and watched the reservoir fill. Filled fast but had lots of air bubbles in it.
Put filter back in and cranked it a few more times.
Started a couple times but died. Finally got it started but sounded to be running on 4 cylinders. Ran for about 5 seconds like that than oil pressure gauge finally came up and than it started running normal.
No codes still
Air tested the hpo system again. No leaks with IPR commanded.
Any ideas? Need some help on this.
Ipr is mid 30%
No codes still
Ipr is mid 30%
No codes still
Ipr is mid 30%
No codes still
I would look up the bubble test and see if you have any injector issues. Its basically as easy as removing the upper fuel filter cap, removing the filter, letting it fill with fuel, turning the truck over and watch for bubbling. If you see bubbles you have an injector that has failed and is letting exhaust gasses through it.
In my experience bad glow plugs (rare they go bad) throw a code.
My truck incidentally had a bad HPOP that I recently replaced. Ran great and then I found 4 bad injectors about 1k miles later. The less than 1 min I let it run it sounded like all the cylinders were not firing and idled real ruff. Also was very hard to start.
Check the O-rings on the standpipes & dummy plugs. You can also get o-ring kits from Sinister diesel for about 8 bucks a kit, Then pull your injectors one at a time, lay out some paper towels, take the little hex head bolt out keeping the orientation the same as you lay the pieces out. Next remove the spool valve again making sure of how it goes back together cause one side is longer than the other. Get some brake cleaner or WD and a small piece of 600 grit wet/ dry sandpaper and lightly clean the spool valve by twisting it in the sandpaper. Reassemble the injector take one of your kits (8 required) and put the new orings and copper washers on. Before you oil em up and slide back in check the injector cup in the head for old copper washers,dirt,parts of orings and any thing else. reinstall your new injector. Oh ***** I almost forgot on mine I also cleaned the nozzle w/ 600 paper all the way out to the very tip. now you can install your semi rebuilt injectors in and smile you just saved your self $2500 cash. hope this helps
