1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
05+ dana 60 outer dust sleeve?
Old 08-22-2014, 02:59 PM
Greg5OH's Avatar
Greg5OH
Greg5OH is offline
I hear the outer dust sleeve (at the end of the axle housing) comes loose all the time. Well, both mine are loose and dangling.
Can i sandwich these back in without removing the whole knuckle? Is there a trick to get em to stay in?
Old 08-22-2014, 03:39 PM
Modularation's Avatar
Modularation
Modularation is offline
Just clean the axle tubes if you ever have to reinstall axles to prevent dragging the axle end through grit and possibly damaging the inner axle seals which will cause gear oil to leak. The outer axle seals will not contain oil that leaks past the inner seals even when they are new. They are just to keep some dust out of the tubes. The older model axle housings did not have these outer seals. You don't have to do all the work required to remove axles just to replace these outer seals. You can do them when you replace hub bearings or ball joints which will be soon enough.
Old 08-22-2014, 04:00 PM
senix's Avatar
senix
senix is offline
Received 1,400 Likes on 997 Posts
fyi..if you get new ones they have updated the part now. likely you won't have to replace them once you buy the updated part.
Old 08-25-2014, 08:58 AM
Greg5OH's Avatar
Greg5OH
Greg5OH is offline
thanks. When I do BJs (hopefully not for a little while) ill ge tthe new ones then.
Old 08-25-2014, 09:49 AM
Iron2's Avatar
Iron2
Iron2 is offline
Here is the updated part number for the axle seals.
AC3Z-1S175-A (BRS-170)
Greg5OH
09-06-2015 12:20 PM
monster79f150
09-02-2011 07:28 PM
jbarefoot
04-06-2011 11:45 AM
rmalottwtes30
09-09-2010 10:51 PM
ivanribic
08-27-2005 01:42 PM
Quick Reply: 05+ dana 60 outer dust sleeve?
