Mishimoto 200° vs. Ford 192° thermostat
I know, I will be doing an oil cooler replacement sometime in the future....however, something I noticed today....I normally have consistant 12-14 deltas on similar drives but has always cooled down quickly when exiting the highway. Today I averaged 8-11, which makes absolutely no sense. ( it did hit 14 once, but quickly dropped down) More drive time will tell if that's a fluke or not.
LOL, I wish I only paid $56....like an idiot, I got excited after Bismic found the things, and ordered directly from Mishimoto.....but, with a lifetime warranty, it may be a deal at $56. Who knows....time will tell.
That's a very good question.... can anyone tell by looking at the pics? I'll contact Mishimoto and ask.
EDIT: I've left message with Mishimoto, I will update about the failsafe when I hear back from them.
EDIT #2: Mishimoto says the t-stat will fail open.....meaning you would see cooler temps, not overheat.
I wanted to change the t-stat twice anyway.
"Fail Safe" is a product by Motorad. It simply has a clip that locks the stat open when/if the vehicle overheats. I've had a couple of these and changed out a few more, they are junk. They fail early and often without any overheating. Any thermostat can fail open if it gets a chunk of crud in in or the spring breaks and it will fail closed if the wax in the center part gets cooked or leaks out from corrosion. There is no thermostat available that I'm aware of that will push it's self open if it fails in the closed position.
I have this 200° thermostat and a Misho radiator on order. I don't expect any issues with the PID's but I'll let ya know if it does anything weird. Just hoping it fits right..
"Fail Safe" is a product by Motorad. It simply has a clip that locks the stat open when the vehicle overheats. I've had a couple of these and they are junk. They fail early and often. Any thermostat can fail open if it gets a chunk of crud in in or the spring breaks or it will fail closed if the wax in the center part gets cooked or leaks out from corrosion. There is no thermostat available that I'm aware of that will push it's self open if it fails in the closed position.
Maybe the metallurgy of the spring is designed to weaken over many thermal cycles in an effort to increase the odds of the thermostat being replaced before it fails, but there is nothing about that plan in any sales literature I've ever seen. (It seems like they design a lot of stuff to fail at a certain point these days- from car parts to toasters)
#29
