This is going to get old.
A couple of months ago I had the problem where my truck wouldn't run after stopping for gas. Had to have it towed back to the dealer. The next day it started and ran fine. No codes. This morning when leaving for work it took about six tries to get it to start. You never know when or where this truck could leave you high and dry. If I had a do over I would take my old 2001 PSD back and fix it up. You can't depend on this new one.
I went out and checked to see if you can hear the fuel pump run and you can if you turn the ignition on but not to start with the seat belt on and seat moved forward so you can hear it. If only runs until it builds pressure and then shuts off so listen close. If the next time it happens and the pump doesn't run bring it back to the dealer and tell him what you found, if they won't look at it call customer service.
Denny
Denny
Is the truck cranking with no start or when you turn the key just nothing happens. My service f150 seems to be that I will turn the key and let go nothing happens then if I hold the key on it will start to crank after approx 1sec so I am wondering if its maybe the auto start key function on yours. (I don't know the proper name but you know how you only need to turn and let go of the ignition )maybe its acting up
ColterDC
1999 to 2016 Super Duty
01-20-2017 01:26 PM
cornstar6207
12-08-2015 06:52 AM
Houston Cowgirl
03-24-2012 10:22 PM
mgm5555
03-24-2003 08:34 AM
