What's going on with my front brakes?
Hello, I have a 2001 F250 7.3 Crew Cab, Long bed, Automatic.
Was driving back from Maryland to PA yesterday and everything was fine. Then, toward the end of my trip the truck started to lose power and it felt like I had a flat tire on the passenger side front tire. When I put the brakes on they pulled hard left.
I made it home and the right passenger side tire smelled like overheated brakes.
About an hour later I moved the truck down to the barn and took passenger wheel off. Everything turned easy and seemed right, a little rub spot but able to turn hub by hand. Took the drivers side off, that was fine, turned easier than passenger side. I could not see anything wrong. Buttoned it back up and took it for a ride. Everything was fine, no vibration, no hesitation.
Any idea what is happening? Could the caliper be binding up and then releasing when it cools down? Could the passenger side be fading when hot causing the left side to pull when I applied the brakes?
Regards,
redbug
Regards,
redbug
Try to grease the slide pins first. It's cheap. Will advise you do 1 at a time. The upper and lower pins are alittle different.
Use Emory clothe or scotch Brite pad to clean up smooth. QTips or whatever to clean hole on caliper.
Easy with the rubber boots. Mine split last time. Dealer item as far as I know.
John2001,
Ok, that makes sense. Good advice.
I had replaced the front brakes about two years ago when one of the calipers locked up. New pads, caliper, two new rotors.
I only put about 3000 miles on this truck a year. Most of those miles are towing trailers, but, the trailers have brakes.
I did notice that the pads were only a little over 1/8 of an inch. I my opinion they are wearing too fast. Also the rotors are wearing fast.
I'll double check the sliders.
I usually do all my own brake work. Had a shop replace the rear pads while in for inspection a about a year ago and they did not grease the sliders... Lost a rotor and almost got stranded with my camper....
I'll post what I find when I pull the wheels off.
Since it doesn't get driven much I would highly advise you to replace those rubber lines. Over time the insides break down and can act as a check valve not allowing the fluid to flow back (that was my brake problem that I almost got rid of the truck because I couldn't figure it out).
Some guys will argue tooth and nail about this but I do not recommend ceramic pads on these trucks! One of the best things I did to my truck was replace the rubber lines and put EBC Green Stuff pads on the front then yellow stuff on the back. If I did it all over again I would go yellows all the way around.
on
Received 3,102 Likes
on
Took the caliper off. The rubber bellows were not sealing on the top pin. The pin was not rusty but it seemed that grease was getting tacky. I'm going to stop by the ford dealer tomorrow and get new bellows.
The pads are pretty rusty probably due to the heat. I'll need new ones come december when inspection comes around.
