Stiff clutch
Old 08-18-2014, 09:30 PM
Snowturtle's Avatar
Snowturtle
Snowturtle is offline
Stiff clutch
Ever since I bought my '97 F250 8 years ago, the clutch has been hard to depress. It works fine, it just takes a strong leg to use it. When I got a new clutch a few years ago, I was sure a new pressure plate would fix the problem but, no, it stayed the same. Then when I replaced my motor a couple of years ago, I installed a new slave cylinder - still stiff. Today I put in a new master cylinder and it hasn't changed. It has never bothered me but now I'm trying to sell the truck and people want to know what's wrong with the clutch. So….what's wrong with my clutch?
Old 08-18-2014, 11:09 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Nothing. Stop being a Sally.
The only thing is if the input shaft bearing retainer is worn and causing the throw out bearing to not slide on it freely.
There's not much going on there to cause resistance. You've replaced everything, so it just pushes harder than some.
Old 08-18-2014, 11:26 PM
Snowturtle's Avatar
Snowturtle
I agree. It works fine so I guess that's just the way it is. I need to find a buyer that's not a Sally!
Old 08-19-2014, 09:16 AM
BigSix1's Avatar
BigSix1
BigSix1 is offline
Subscribed.
dizzyfingers03
38
03-16-2011 01:27 PM
charlessocccer
34
12-15-2010 03:17 PM
Zach Sprunger
17
10-29-2009 09:39 PM
mustanginca
17
06-04-2007 06:46 PM
sobsidian
1983 - 2012 Ranger & B-Series
04-30-2004 10:03 PM
Quick Reply: Stiff clutch
