Back in the Bio again!
Here are the steps I use:
1. Collect WVO
2. Filter WVO to remove large chunks
3. Fill reactor w/ 37.5 gallons of oil (using 50 gallon water heater)
4. Heat to 125 and add glycerol from last batch
5. Circulate and let glycerol settle out.
6. next day - drain glycerol, recover methanol from it.
7. Test Titration Levels of WVO
8. Heat WVO to 125 F and turn off heat
9. Add Methoxide (5 gallon methanol + about a gallon recovered from prior batch) to Heated WVO slowly, about 20-30 minutes
10. Mix the mixture for about 2 hours(pump mix)
11. Let it sit
12. next day - Drain off Glycerin from the bottom of tank, save for treatment of next batch
13. Recover Methanol then dry wash with Magnesol. Let set a couple days.
14. Filter bio
15. use bio
I pretreat due to some of my oil is rather acidic. by pretreating I neutralize some of the acidity. If you have really good oil you can skip this step, might want to anyway... I just seem to get better bio this way...
1. Collect WVO
11. Let it sit
14. Filter bio
15. use bio
Welcome back Jim. I knew you wouldn't quit. I'm still plugging along. I don't recover my methanol. Pain in the butt. What is your recovery process? Maybe I am not doing it efficiently.
What happened with the methanol/KOH mixture? Did it get too hot? I notice the mix gets very violent when it is hot out. I leave plenty of ullage space when pouring in KOH and I do it in 2 steps (4gal methanol/2 lbs KOH)
I've been very busy so I don't get on this Forum much any more. I see there is a new "breed" on here now. Lots of WMO processors. I'll stick with WVO. Don't think I'll ever go with WMO. Fabman would "be all over me like a cheap suit" There are still some of us "purists" around.
Good luck with your endeavors.
Tom
Tom
whiteaddiction
Bio-diesel, Propane & Alternative Diesel Engine Fuels
10-28-2009 09:54 PM
Rushmore X
02-16-2009 12:51 PM
6.0superduty
03-19-2008 11:44 AM
RDC F250 7.3
18
07-31-2006 09:38 PM
