2005 f250 6.0l super-duty fuel pump wiring
Well hello to every one Here is my problem I just bought my first 2005 ford f250 6.0l via cash bid from a bank now I'm in process of repairing the truck I'm sure I will have many problems that I could use help with for the truck has many but this is what I'm on right now. I had to buy a new automatic transmission wire harness. I installed it on the truck but when I went to plug up the fuel pump the male pin connecter was damaged from the the owner before me I have the plug and wires that go to the fuel pump What I can't find is a wire diagram that shows what wire go's to what pin in the plug Thanks for the help if any more info on the truck is needed just let me know
Welcome to FTE.
Lets see if one of the Mods will move this to the right place.
6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
I put 2 PDFs on this post the Engine one you want to look at 26-2
for the fuel pump. Tis diagram is for a 2006 and should
still work for the 2005.
I also put the ground diagram up for you also.
Sean
Sean
BURNSTOUGHFORD
40
03-27-2013 05:22 PM
Breaker Breaker 3-3
01-27-2013 12:58 PM
Breaker Breaker 3-3
06-24-2010 09:46 AM
