Guess I'll get some rust inhibitor till I'm ready to do some body work on the truck! #Texasweather probably had to do with the seal giving way (hotcoldhotcoldhotreallyhot).
I'm going to have to go out and check mine now. I know I have rust in the rear lower corners of the rear door windows. I need to pull the outer window seals off and touch it up.
Almost looks as if someone pried out on that lower channel in two spots. If this is the case I would clean it out, spray it with some paint or such and seal it with some exterior quality caulk sealant.
