F15=F150 2WD pick up
H=351 cid 2bbl V8
C=Ontario Truck Plant
CC0535=1978 model year.
What doesn't jive?
Look at your frame VIN to be sure it matches the warranty plate on the door. It's easy to change a door, frame...not so easy.
You need to check the frame VIN, the F15 is for 2WD not 4 wheel.
I think you're going to find the VIN begins with F14 (assuming it is a 150 and was originally 4WD and not a conversion.
Frame VIN# is on the passenger side frame rail, across from the exhaust manifold, in front of the riveted mount for the cab at the edge of the C-channel
There's also a second location further back on the same rail, but it's under the foot well and difficult to see.
