4.6 timing problems
Old 08-18-2014, 01:03 PM
eddieburnsii's Avatar
eddieburnsii
eddieburnsii is offline
4.6 timing problems
Engine will only rotate 180 either way (by hand with a ratchet and socket) before something hits internally. Everything seems to be correct as far as I understand. I have attached pics of what I have. Any help will be greatly appreciated.
passenger side cam
driver side cam
crank gears marks are at the 6 o'clock position with the red links on chains lined up
overall pic
Old 08-18-2014, 03:46 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
Did you stretch out the chains like l=============l to make the marks? The links on either end are the ones to paint. What happened to make yo take it apart in the first place?
Old 08-18-2014, 04:04 PM
eddieburnsii
Yes the chains were stretched and marked l========l . It initially blew a spark plug out of the #3 cylinder. The head was removed to fix. After initially getting the timing incorrect and breaking 3 valves and bending one, my friend got a "new" used head for it. After sitting for awhile he is back to messing with it and is hoping to not repeat any mistakes.
Old 08-18-2014, 06:23 PM
70f100longbed
If its in time then something has to be on top of a piston or maybe a rod got bent and the piston skirt is hitting a crank counterweight. I know it's too late but there are repair kits for the stripped spark plug holes that don't require removing the head. Cal-van makes a very good kit and I have installed maybe 20 and have not had one come back.
snorindad
1997 - 2003 F150
05-16-2018 01:53 PM
billingslm1
08-11-2011 10:11 PM
mobilefleet
06-07-2010 06:13 PM
C.hill
65
03-29-2010 10:15 PM
Quick Reply: 4.6 timing problems
