E4OD, anyway to bypass VSS switch on differential?
#62
#63
Simplified test might just narrow it down fast for ya.
#64
Thanks a million you all, you guy's should be running the planet for sure and then maybe we could be going the right direction. I have one of those Centurion over head lights and I pulled the light apart in the center and the problem seems to have gone away. This light is nothing like the stock Ford setup but who cares!
I will go for a drive.
#65
#66
on
that's what you get for keeping costs down though.the price of the trucks would have had to cost more.it was cheap to wire it up the way they did.
when the power wire shorts out on the 7.3l idi fuel filter heating element it blows the power to the trans.not very wise either.
they could have cleaned up the E40D's wiring greatly with just a few devoted circuits.
the good thing is,we pretty much know all the common wiring issues and typical reasons for blown fuses associated with the trans operation,so you've only got to search or ask here and get it figured out pretty quickly.
now you learned to try and keep away from the stealership and check here first.
#67
How hard is it to fix the wiring on this stuff say like you are rebuilding a area or something on the truck. If you are going to make something more complicated electrically at least do it right.
Are any of the other generation trucks alot better about this kind of stuff? like earlier or later?
again thankyou for all you help you all!!!!
#68
Glad to see you found the root cause.
#69
My 2006 Mustang GT has it's fair share of fuses and two boxes as well.
Both vehicles require a GPS to locate the correct fuse.
#70
#72
Come to think of it. ...I do not know where the fuse box (es) is.
#73
#74
"Least headache" is usually a new truck. They might be horrible to work on, but they'll rarely need it (at least until they aren't new). They'll also get better mileage that anything older that's comparable.
If you want an older truck, then it depends on your definition of headache. Older, non-computer controlled trucks are definitely simpler to work on. But (relatively) newer computer controlled trucks like your '94 will break down (relatively) less often and get better mileage.
I've got a '71 Bronco and a '97 F-250. There's no question that the '71 is easier to work on, but it simply doesn't work as well as the '97. Little stuff like cold starts and hot restarts, both of which the '71 does not do well. Which is less headache? For me it's probably the '97, bit YMMV.
Added in edit: By the way, the E4OD is about as bulletproof as transmissions come. Sure it doesn't work right when sensors go bad, wires break or fuses blow. But they seem to go a LONG time before needing to be rebuilt. And the minor electrical things are just that, minor. They can be hard to track down if you don't know what you're looking for, but fortunately there are a lot of people on this board that can help us with that! The C6 was a really good trans too, but I don't think it's got anything over the E4OD in terms of longevity. It's simpler, but it also has no lockup torque converter or overdrive. Again, you choose what is more important to you.
