Parts neede for HPFP replacement
So the old beast threw the p0088 code. Guess that the HPFP is on it's way out. Gonna have to book some time in my garage and switch it out. I am curious what parts are needed in order to do the repair. Can all the gaskets and seals be used again? Does the pump come in a kit?
If you are planning on doing the repair yourself in your garage, I assume it means you plan on NOT lifting the cab. If that's so, all I can say is HAVE FUN. You know the HPFP is not light by any means, and neither are the turbos (which will obviously need to be removed if you're not lifting the cab). That said, you will need a turbo kit (don't know the part number off the top of my head). The gaskets and lines should all be included with the HPFP, along with the big thick blue zipties for the VCV and PCV connectors. GOOD LUCK.
Thanks for the feedback. Talked to a couple of dealers about the pump and one said that I would also need to replace the pump cover as it was updated. Anyone hear of any update like that? I haven't read anything on that. I realize they changed stuff on the 08's with the wire placement, but mine is a 2010.
16Vjohn
10-19-2010 07:17 PM
Hydrocarbon302
08-06-2010 11:52 PM
