lug nut torque spec 1977 F150
Old 06-26-2014, 03:05 PM
MIKEDENGINEER's Avatar
MIKEDENGINEER
MIKEDENGINEER is offline
What is the torque spec for the lug nuts on a 5 lug 1977 F150 4x4? I'm doing 100ft/lb and I've been checking it every 50 miles since I put new rims on and the fronts I can always rotate them about 10 degrees till the torque wrench clicks... I'm nervous....
Old 07-07-2014, 08:34 AM
MIKEDENGINEER
So...
I have now put down the torque wrench and went back to what I've done for years. Use a 1 foot long wrench and step on it. This seems to working as the lug nuts are staying tight.
I'm guessing they should be about 150 ft/lbs on the five 1/2 studs.
Old 07-07-2014, 08:15 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
Here's what Budd specified. Accuride and Kelsey-Hayes are similar. I assume yours are steel, not alloy. On stud piloted nuts they specify dry torque. If yours are not holding torque the studs and nuts might need to be replaced. Stu
Old 08-13-2014, 10:57 AM
MIKEDENGINEER
Thanks for the info! The nuts are holding tight as I tightened them by hand and don't know the torque.
wb6anp
2017+ Super Duty
06-01-2017 01:11 PM
Leon82
1999 to 2016 Super Duty
07-27-2014 05:42 AM
joeycyph56
05-02-2007 07:50 PM
VARichWilson
Escape & Escape Hybrid
08-11-2004 07:01 PM
damonlan
1997 - 2003 F150
01-18-2003 11:36 PM
Quick Reply: lug nut torque spec 1977 F150
