gauge install tips
gauge install tips
hey everybody just got some autometer gauges in ( cool temp, oil pressure, and volts) and i was wondering where do all these gauges go or i should say where are some good places to mount them too and where is a good place to go through the fire wall. this is going on a 95 f150 with a 5.0. if anybody got some links that would be appreciated.
On a 95 your best bet for a clean looking install is either on the windshield pillar, a gauge pod on top of the dash, or in a custom center console. The shape of the instrument panel itself does not really leave any flat surfaces to mount them.
I'm sure others will chime in with actual pics of their installs!
I mounted my gauges on the A pillar. Coolant temp sender was installed using the autometer heater hose sending unit mount. I installed inline on heater hose that goes from t-stat to heater core. Voltmeter wiring was installed at fuse panel using those add a line fuse links that plug into fuse holder and allow you to add a fused line. The wires were all run under carpet through rubber grommet for trans shift cable. It is near accelerator pedal.
I ran a trans temp gauge instead of an oil press
