Go Back  Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Reload this Page >
Rusted/Stuck Part Shootout: Dry Ice vs CRC Freeze Off vs Acetone/ATF Poultice vs PB Blaster
Old 08-11-2014, 08:36 PM
F350 1990's Avatar
F350 1990
F350 1990 is online now
F350 1990 is gaining momentum as a positive member of FTE.F350 1990 is gaining momentum as a positive member of FTE.
In today's shootout we took on some seriously rusted/frozen exhaust manifold bolts on an old 390 employing:
(1) Dry Ice
(2) CRC Freeze Off / Super Penetrant
(3) Poultice consisting of talc power, ATF, and acetone
(4) PB Blaster
The above were individually applied to two randomly selected rusted bolts across both banks. The Dry Ice was held in place for approx 30 minutes per bolt. The CRC Freeze Off application consisted of three 30-second sprays. The Poultice was brushed on and covered up with talc powder and cellophane wrap to prevent the acetone from evaporating, then allowed to remain on the bolts for approx 4 hrs. The PB Blaster application consisted of three 10-second sprays followed by an approx 4-hr wait before attempting removal.
Results:
Dry Ice was the clear winner (allowing for relatively easy bolt removal) followed by the Poultice which worked on one of the test bolts but failed to loosen the other for removal. CRC Deep Freeze / Super Penetrant and PB Blaster tied for last place and did little as the bolts remained "frozen".
Old 08-11-2014, 08:50 PM
eakermeld's Avatar
eakermeld
eakermeld is offline
eakermeld is gaining momentum as a positive member of FTE.eakermeld is gaining momentum as a positive member of FTE.
How did you hold the dry ice in place? Got pics?
Old 08-11-2014, 08:58 PM
krooser's Avatar
krooser
krooser is offline
krooser is gaining momentum as a positive member of FTE.
With gloves...
Old 08-11-2014, 09:03 PM
eakermeld's Avatar
eakermeld
Originally Posted by krooser View Post
With gloves...
For 30 MINUTES!?! I would need 2 potty breaks in there somewhere! That's......like.......3, maybe four beers!
Old 08-12-2014, 05:29 PM
F350 1990's Avatar
F350 1990
Didn't take pics but we cut up some styrofoam as a "v" jig (along with a Irwin Quick Grip) to hold the dry ice in place.
Pretty impressive how well the dry ice worked. Pretty unimpressive how the "canned" sprays didn't work.
Old 08-12-2014, 05:34 PM
F350 1990's Avatar
F350 1990
Actually you don't want to hold dry ice or hang around it in a closed in area --- it displaces oxygen and you'll end up getting hypoxic before you know it.
Old 08-14-2014, 09:21 PM
Roger T. Pipe's Avatar
Roger T. Pipe
Roger T. Pipe is offline
Roger T. Pipe is starting off with a positive reputation.
Thanks for posting this...it's very helpful! Just a thought-have you ever tried Kroil? I have NO idea whats in it, but it has NEVER failed me, including rusted-on exhaust parts! It isn't cheap, something like 18.00/can, but it does what it says-period.
Roger
Old 08-14-2014, 11:01 PM
joey2fords's Avatar
joey2fords
joey2fords is offline
joey2fords is gaining momentum as a positive member of FTE.joey2fords is gaining momentum as a positive member of FTE.
sorry, but 8 bolts is much too small a sample to draw any sort of conclusion from.
Old 08-15-2014, 12:06 AM
Evan_P's Avatar
Evan_P
Evan_P is offline
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
I swear by PB-Blaster. If you let it soak in for a day or two it works great. Never broken a bolt using the stuff.
Old 08-15-2014, 04:40 PM
F350 1990's Avatar
F350 1990
Roger
Yes I have, it's been around many many years and does very well in tests (see below from Machinist's Magazine)-- next shootout we do in my shop we'll add it to the mix of competitors.
Penetrating oil ..... Average load
None ..................... 516 pounds
WD-40 .................. 238 pounds
PB Blaster ............. 214 pounds
Liquid Wrench .... 127 pounds
Kano Kroil ............ 106 pounds
ATF-Acetone mix....53 pounds
Old 01-03-2015, 04:16 PM
F350 1990's Avatar
F350 1990
Six-Month Update on the Shootout
Inputs from five shop mechanics along with ongoing tests on 40-50 year old tractors (e.g 1966 JD 2510) and farm implements ---- latest summary opinions below. Dry ice remains the winner and we have not yet found a frozen nut/bolt it couldn't handle. The surprises were how well molasses and the oil of wintergreen worked. Pepsi also outperformed PB Blaster which really surprised us. Adding the farm implements (many sat in fields for years) allowed us to try the competitors below individually on similar bolts in a particular section of the implement which helped remove some bias in our opinion polling.
(1) Dry Ice
(4) Oxy-Acetylene or Oxy-Propane w/candle wax
(5) Kroil
(6) Oil of Wintergreen
(7) Molasses
(8) Pepsi
(9) PB Blaster
(10) WD-40
(11) Liquid Wrench
Old 01-04-2015, 08:56 PM
jaagen's Avatar
jaagen
jaagen is offline
jaagen is starting off with a positive reputation.
Do you think the dry ice works so well is it contracts the bolts
Old 01-04-2015, 09:03 PM
78 PEB's Avatar
78 PEB
78 PEB is offline
78 PEB is gaining momentum as a positive member of FTE.
Aerokroil is my friend.............never has let me down. Give it plenty of time to soak (overnight) and you wont find anything it wont work on.
Old 01-04-2015, 09:11 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
Sea Foam Deep Creep is my go to at work . At home I also use brake fluid on old rusted stuff where finish does not matter . Amazing how well it works .
Old 01-04-2015, 10:03 PM
Tedster9's Avatar
Tedster9
Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Marvel's has wintergreen oil in it, that's why it works so well for stuck rings and lifters or so I've heard.
Quick Reply: Rusted/Stuck Part Shootout: Dry Ice vs CRC Freeze Off vs Acetone/ATF Poultice vs PB Blaster
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
