Well, it's almost time. 51 F1
Old 07-20-2017, 08:00 PM
mustangmike6996's Avatar
mustangmike6996
mustangmike6996 is offline
It was just mufflers exiting straight back and the noise in the cab was LOUD!
I shortened the flow tubes, and cut the old tail pipes down for the side exit and its very quiet at idle now. When I let it rip it gets pretty noisy but not bad in the cab.
  #377
Old 07-20-2017, 10:01 PM
52 Ford F1's Avatar
52 Ford F1
52 Ford F1 is offline
Like the side exhaust idea, how does it look from standing level?
  #378
Old 07-20-2017, 10:06 PM
mustangmike6996
  #379
Old 07-21-2017, 05:44 PM
mustangmike6996
You cant really see the pipes unless your kneel down and look, which is what I wanted.
I function tested the power steering hose and it seems to be holding. I did notice a slight fuel leak at my return line from the regulator so I will address that tomorrow.
  #380
Old 08-08-2017, 08:42 PM
mustangmike6996
Took care of the fuel leak. Needed to reseat the AN line.
The power steering is fixed and runs great.
  #381
Old 12-18-2018, 09:01 PM
mustangmike6996
Its been a while so I figured I'd check back in. Nothing new with the truck, just keep putting miles on it when its nice out. I am considering a few things to upgrade:
Electric wiper motor
Lowering the front ride (might remove a coil or 2, drop springs or air-ride)
Redo the bed wood
Still want to take care of the interior
The big thing I have been focusing on is cleaning up some of the sloppy work I did on the truck to make it more presentable.
  #382
Old 12-18-2018, 10:05 PM
EBEAR's Avatar
EBEAR
EBEAR is offline
Glad to hear you're enjoying it the work is never finished .
  #383
Old 08-25-2020, 04:42 PM
mustangmike6996
A quick update, I haven't been on here in quite some time:
I had a fuel starvation issue so I decided to swap my fuel tank/pump setup. I went with a Tanks Inc 1969 Mustang tank, baffled. It has a Fitech in-tank pump. I am also rerunning my return line and cleaning things up a bit.
I also cut a coil our of the front struts, the truck was riding very rough and there wasn't much give when compressing the suspension. I am considering going with air ride but I'll need to do something with the rear frame (c-notch most likely). I am also considering getting rid of the leaf springs and going with parallel bars.
Any suggestions on a cost effective rear suspension setup?
hillcogolfer
07-08-2018 07:01 PM
Anderson Becheli
02-05-2017 10:26 AM
PistonPat
29
12-05-2015 01:26 PM
VineMan
08-21-2014 01:00 PM
JBjorgaard
09-17-2011 10:33 PM
Quick Reply: Well, it's almost time. 51 F1
