Well, it's almost time. 51 F1
06-21-2017, 04:14 AM
Something happened to the lock pin, probably easier to remove the switch and check it. The pin is spring loaded, probably just stuck.
06-21-2017, 12:24 PM
on
That's what I figured. I did remove the switch and I still cannot get the rod locked in.
Any suggestions on where the best place to buy a repop switch and maybe a new rod?
06-21-2017, 02:04 PM
on
I was able to modify an extra switch from my 1969 mustang
on
06-21-2017, 03:04 PM
Quote:
Originally Posted by
mustangmike6996
I am glad you did this can you post more pic
Are you drilling a new hole
06-21-2017, 06:48 PM
on
I moved the switch next to the ignition key switch when I put the new column in. It actually seems to fit quite well. I need to install my tach when NVU sends it back.
06-21-2017, 07:21 PM
on
06-21-2017, 07:22 PM
on
06-21-2017, 07:35 PM
06-21-2017, 07:48 PM
on
No problem. I was in a pinch and I had extra parts so I made it work.
06-23-2017, 07:04 PM
on
Took the truck to a local car show. Everything was good. Pulled the truck in the garage and noticed a burning rubber smell. Found the lower radiator hose shifted and was being cut into by the power steering pump. Oops!
Got a new hose on it today. Added a retainer with an isolator to keep it away from the pulley.
07-20-2017, 07:19 PM
on
Found my high pressure power steering line was leaking. Rebuilt it with the extra PTFE Russell hose I had (and reused the 45* fittings)
Going to adjust the clutch cable tomorrow to address a high RPM grind when shifting.
07-20-2017, 07:30 PM
on
I also built side exit exhaust.
07-20-2017, 07:31 PM
on
07-20-2017, 07:56 PM
How loud is that? I had to make full tail pipes just to get it reasonable inside the cab.
