Ford Factory Foglights installation
Is there certain steps that need to be taken in order to install the factory (OEM) foglight wiring harness into a 2004 F250 SD XL? I have installed the switch and fog lights, but having difficulty with installing the foglight harness.
So far I removed the bumper and grille but had to stop at the grill frame that the grille mounts to. The frame is attached to the left and right headlights. The harness is the last item I need to install so that my F250 has operational factory fog lights.
Any suggestions or images would be appreciated.
Not sure. Your engine type is different then mine
so the under the hood layout will also be somewhat
different. Get a mirror and flashlight and you may find
a path to get in there to make the connection. Also they
will sometimes store it a bit away from where it will be
when installed.
Sean
when installed.
Sean
You can always post a photo of where you stuck
trying to reach from the one point to the other.
Here is a good how to post photos.
https://www.ford-trucks.com/forums/1...he-forums.html
You can also use the upload from you local hard drive if you like. I find it
a lot more easy them PhotoBucket then putting the link it.
Sean
Sean
I forgot about that detail.
He may have to run some harness wires up into the cab.
I'll attach some wiring diagrams PDFs to this for the 04.
Sean
