1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Play in steering wheel
Old 08-18-2014, 09:47 AM
tvannaman2000's Avatar
tvannaman2000
tvannaman2000 is offline
I have a '99 F250 w/ PSD with 165k miles.
When I drive, I move the steering wheel and nothing happens for the first few degrees of turn and then I encounter resistence and it turns. It's the same either way. The vehicle seems to track nicely, doesn't pull to either side, just a lot of slop in the steering wheel.
Is there a way to determine if this is really steering related or is it just loose/worn front end suspension parts making themselves known? My guess is suspension items, but the fact the front end behaves itself when the truck is moving has me doubting that just a bit.
Thanks,
Tim.
Old 08-18-2014, 09:53 AM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
The steering components would be the first place to look. Ball joints, tie rod ends, etc. If that all checks out, it could be in the steering box. Is your truck a 4x4? And has the front end been rebuilt before? I had my 02 done back over the winter for the first time with close to 140,000 miles on it.
Old 08-18-2014, 09:54 AM
VindexInjuriae's Avatar
VindexInjuriae
VindexInjuriae is offline
Steering gear - they're a known/common issue. It can be adjusted via the allen bolt in the top of the gear, but that's a temp patch more than anything. A lot of members here seem to like the Red Head steering gears when they replace the worn stock part....
Old 08-18-2014, 01:10 PM
tvannaman2000
Great info... now, someone needs to post how to replace or adjust a steering gear!
Old 08-18-2014, 01:12 PM
tvannaman2000
[quote=CampSpringsJohn;14592521] Is your truck a 4x4? And has the front end been rebuilt before? [quote]
It is a 2WD and idk about the front being rebuilt. I just bought it several weeks ago, but I would guess that no work has been done it. Carfax showed no accidents.
Old 08-18-2014, 03:56 PM
CampSpringsJohn
On top of the gearbox is an allen screw with a lock nut. You back off the lock nut, making sure to watch the allen screw. If it moves, then you need to move it back from where it was when you broke the lock nut loose. Then you tighten it about 1/8 to 1/4 turn, and tighten the lock nut, making sure the allen screw does not move. Then take it for a test drive and see if that fixed it. Before doing this, I would make sure everything else is in good shape. If you over-tighten the gear box you will create bigger problems.
rmurray
10-27-2012 08:56 AM
BigBlue92
09-06-2011 10:34 PM
kstiner
29
11-18-2009 10:36 AM
Stapler123
09-03-2003 08:14 AM
shawn
08-15-2003 01:12 AM
Quick Reply: Play in steering wheel
