Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Poulan chain saw runs fine for 30 sec to 1 minute, then dies
Old 09-13-2014, 02:41 PM
fellro86's Avatar
fellro86
fellro86 is offline
I have a chain saw I inherited from my uncle. I had to replace the primer ball and the fuel lines, as well as a diaphragm from the carb. It runs just fine for around 30 seconds to a minute, then dies like I shut it off, but I can see that it still has spark with an inline tester, and the primer bulb is still full of fuel. I am at a loss, and am looking for ideas how to get it to stay running. Pumping the primer bulb doesn't help either.
Old 09-13-2014, 03:57 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Sounds like (maybe) bad fuel over time has oxidized and gummed carb jets orifices Have you tried cleaning the carb e.g. how far did you take the carb down
Old 09-13-2014, 08:47 PM
fellro86's Avatar
fellro86
fellro86 is offline
Carb looked clean. I got it going, mostly. Found that the fuel line that was actually the main supply line independent of the primer line was broken. Had to figure out where it went, then got it worked through. Ended up doing the same with the primer line as well. Still had the issue, so I had found some had to run the mixture screws in to clear the passage, then back them out. I suspect I need to turn the high speed screw a bit more, as it wavers at full throttle now.
Old 09-13-2014, 09:09 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Good deal. What are you running for the mix? I like the Opti - it's good stuff and suitable for all 2 cycle equipment at 70-1 or so.
Old 09-13-2014, 09:25 PM
fellro86's Avatar
fellro86
fellro86 is offline
This round I put Lucas in, I think. I started monkeying with it a month or so ago, and been a couple weeks just getting parts in. I only get a chance to get the parts picked up on weekends, so I would wait all week to get them. First was a primer bulb, then the carb kit. I know it was a synthetic that claimed to be good for multiple mix ratios. I mixed the gas about a month ago now...
Old 09-13-2014, 09:43 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Supposedly Opti isn't a synthetic? I dunno. Works good, haven't had any problems. The lawn care folks seem to like it too from reading those forums.
Old 09-13-2014, 10:14 PM
fellro86's Avatar
fellro86
fellro86 is offline
I didn't grab it so much for being synth, just was available and reasonably priced.
Old 09-14-2014, 09:25 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Well there's that. I bought a gazillion of those little packets that make up a gallon from eBay.
Old 09-15-2014, 07:14 AM
lariat97's Avatar
lariat97
lariat97 is offline
Ethanol took out all the fuel lines on my mid 90s Poulan saw, The replacement lines are able to handle it. Its tough to replace some of the lines. I put my car in my vat while I found replacement parts. It runs great now.
Old 09-15-2014, 09:23 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
That's a pretty good sized vat, sounds like?
Old 09-18-2014, 05:42 AM
lariat97's Avatar
lariat97
lariat97 is offline
Carb i meant. I need to proof read my post
Old 09-19-2014, 09:53 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
I run the Lucas in most of my stuff, from chainsaws to dirtbikes to sleds and even my Lawn Boy.
Make sure the spark arrestor isn't gummed or plugged, it's the little screen in the muffler.
A popular trick from the Lawn Boy group is to bake the muffler on the grill for a while to dry out all the gum so it can be shaken out.
Old 09-19-2014, 09:59 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
What's the mix ratio for the Lucas oil?
Old 09-20-2014, 09:44 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
It's multi-ratio, I run it at 50:1 usually.
Sent from my C771 using IB AutoGroup
Old 09-20-2014, 10:18 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Ok. Opti guys are running 70-1, some even higher. I like it because it doesn't smoke. The packets are 70-1 so that's easiest to figure. It's nice not to have three or four different mixes. Use it for lawnmower, sno-blower, weedwacker, etc.
FordsOnlyGarage
11-17-2018 08:43 AM
BigAKTruck
04-25-2015 08:53 PM
red rock 78
03-11-2009 07:42 AM
F250racer
07-01-2008 09:38 PM
cool 48
02-02-2008 12:15 PM
Quick Reply: Poulan chain saw runs fine for 30 sec to 1 minute, then dies
