Truck sounds and a water pump which shouldn't!
Just took some videos of my trucks, which I thought I'd post:
My second truck's waterpump... How is this not leaking 0.o?
My second truck, start and run:
My main truck, start and run:
Also, how to bleed injectors properly(forgot to upload this before):
In your first video, the play your seeing is not caused by the water pump, thats from the bearings in the fan clutch getting worn, to check the water pump play you have to take the belts off to check it.
I don't know if I want to know this, but what on earth happened to truck number 2 with the wiring? Looks like someone went a little wire happy or something
