Turbo surging in 4th gear only
Old 07-30-2014, 07:41 PM
2006powerstroke90's Avatar
2006powerstroke90
2006powerstroke90 is offline
When I am driving down the highway my turbo will surge. I can watch it on the gauge going from 25 down to 20 and right back up it will do this until I let off or change gears.
Is this normal for a stick shift?
Changed the fuel filters and nothing changed. Thanks.
Old 07-30-2014, 08:17 PM
9228.bobcat's Avatar
9228.bobcat
9228.bobcat is offline
Sounds as if the vgt and or turbo needs cleaned.
Old 07-30-2014, 08:32 PM
04badford's Avatar
04badford
04badford is offline
Can you monitor VGT , MAP, EBP ? do have EGR or delete
Old 07-30-2014, 09:35 PM
cheezit's Avatar
cheezit
cheezit is offline
Unplug ebp. Does it still happen? If so suspect bad vgt sensor. Swap in kowen good one to test.
Old 07-31-2014, 02:09 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
Stiction only (mostly) happens when the engine is cold.
Once you have warmed up it goes away. It's more like
a miss or ruff idle.
Sean
Old 08-01-2014, 07:12 AM
2006powerstroke90
Would there be something electronic causing this?
I tried it again on the highway last night, all gears pull perfectly besides 4th...
If I have to pull the turbo I will, but id prefer not to!
I will pull the EBP sensor today before I head home and see what happens
Old 08-01-2014, 01:32 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Go with with what Cheezit said.
Sean
Old 08-01-2014, 07:18 PM
04badford's Avatar
04badford
don't pull it just unplug the connection
Old 08-05-2014, 06:47 AM
2006powerstroke90
Took out the EBP sensor, thing was plugged solid, cleaned it and no more surging
Old 08-05-2014, 08:36 AM
9228.bobcat
Glad you got it fixed. And thanks for coming back and posting what resolved the issue. That cheezit seems to know what he is talking about.lol
spinge
05-06-2019 07:25 AM
skysoldier69
12-01-2009 10:52 AM
TheDuke
09-01-2007 03:33 PM
Big
11-20-2006 11:24 PM
plumberman57
10-06-2006 10:18 AM
Quick Reply: Turbo surging in 4th gear only
