1949 F4 V8 to Mercedes diesel build thread
  #316
Old 08-31-2018, 05:14 PM
Mixer man's Avatar
Mixer man
Mixer man is offline
Very nice. I would love to find a 4,000 rpm 6 cyl. tach that size.
  #317
Old 09-01-2018, 04:26 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
Thank you, Bob. Summit does list a VDO 0-4000RPM tach, but in the description it states that it is for a diesel. It may receive it's signal from an alternator instead of the ignition, so I don't know if it would work for you.
Mark
  #318
Old 09-01-2018, 11:20 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
6v or 12v? Check Faria Instruments, they have lots of marine instruments, high quality, should have one like that, but only 12v.
  #319
Old 09-07-2018, 03:17 PM
49fordv8f4's Avatar
49fordv8f4
A little more progress.
I made a larger heater control mounting bracket so I could add a water valve control cable and a cigar lighter to power a GPS and a phone charger. I will replace the lighter **** with a tan one to match the other *****.
The original bracket.
The water control valve and cable.
I also painted and installed the tail light brackets and tail lights.
The driver's side.
Thanks, Mark
  #320
Old 09-07-2018, 03:40 PM
Mixer man's Avatar
Mixer man
Nicely done, but inquiring minds want to know how you made the larger bracket so perfect.
  #321
Old 09-07-2018, 04:36 PM
49fordv8f4's Avatar
49fordv8f4
Bob, I have several shot scraps of aluminum I beam, I used a piece to machine the bracket out of. I use a Bridgeport manual mill with a Newall digital readout.
Aluminum angle would have been easier, but this is what I have. I also machined a bracket to mount the two flashers under the dash out of the same material.
Actually both pieces are fairly simple mill work.
Thanks for your reply and kind words, Mark
  #322
Old 09-07-2018, 06:21 PM
Mixer man's Avatar
Mixer man
Well, that 'splains it perfectly. Yeah, a ball head cutter. It's always nice when you have the right equipment too.
  #323
Old 09-29-2018, 04:58 PM
49fordv8f4's Avatar
49fordv8f4
I temporarily mounted the bed clearance/marker lights today. I mounted them on pieces of flat belting left over from my milling machine. I will remove them and paint the belting black and repaint the light housings.
The amber front corner.
Mark
  #324
Old 09-29-2018, 05:00 PM
49fordv8f4's Avatar
49fordv8f4
Adding photos one at a time.
The inside of the front showing the rubber mount.
Mark
  #325
Old 09-29-2018, 05:02 PM
49fordv8f4's Avatar
49fordv8f4
The back corner.
I need at least one more of these red Cats-Eye lenses.
Mark
  #326
Old 09-29-2018, 05:03 PM
49fordv8f4's Avatar
49fordv8f4
Inside back corner.
Thanks, Mark
  #327
Old 09-29-2018, 07:20 PM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,597 Likes on 1,443 Posts
I love those lights. Most people call them beehive lights. I just went to eBay and searched "Vintage red beehive lights". I found several.
Your bed looks great, by the way.
  #328
Old 09-29-2018, 07:49 PM
Mixer man's Avatar
Mixer man
Cool looking lights. Looks like "watermelon" glass lenses. Did you get them from United Pacific?
  #329
Old 09-29-2018, 08:13 PM
49fordv8f4's Avatar
49fordv8f4
Thanks, Abe and Bob. I bought the lights at a local flea market/antique mall. I bought 5 NOS in the original boxes, all amber. They have 6V bulbs and fabric covered wire pigtails, so I would assume that they were from the early '50s. I really like the shape of the lense.
I found this red lense at a swap meet, but I need at least 1 more.
Mark
  #330
Old 09-29-2018, 08:30 PM
49fordv8f4's Avatar
49fordv8f4
Here is a photo of the box and one of the lamps up close.
I would actually love to find 4 red lenses. I have an ICC light bar with 3 amber lenses in it that I would like to mount on the rear of the truck.
Thanks, Mark
Quick Reply: 1949 F4 V8 to Mercedes diesel build thread
