1949 F4 V8 to Mercedes diesel build thread
#301
#302
Thanks again, Mark
#304
I am testing each circuit as I go for continuity to the correct fuse or relay and with a 12V battery to make sure the circuit works and doesn't interfere with any other circuit. I have had to move a couple of circuits on the panel, because when I tested them, they were tied internally to another fuse or relay that I was already using for something else. It has been an interesting puzzle.
Thanks, Mark
Thanks, Mark
#305
There was a thread on the HAMB on "neat wiring", I saved these pics off there. The waxed-string lacing is tough to do.
#307
I have the wiring harness done, ready to remove from the mock up dash and firewall. I still have a little work to do on the wiper motor mounting brackets, then I can start the harness installation. Here are a few photos.
Here is the harness from the firewall side. The wire bundle going straight down from the firewall hole are the wires to the dimmer switch and the rear of the truck. The bundle angling off to the right of the photo are the wires to the front of the truck. The bundle going across to the left of the photo go to the alternator and glow plug relay.
This is the back of the dash.
The back side of the fuse panel.
The fuse panel mounted on the inside of the mock up firewall. The box just above the fuse panel is the Tach control. It changes the gear tooth sensor signal from the flywheel to a standard 8 cylinder tach signal.
Another shot of the harness coming out of the firewall hole.
I will probably only tape the wire bundles out side the cab.
Thanks, Mark
Thanks, Mark
#312
Looking good Mark. Seeing your elaborate mock-up and the seemingly miles of wire you are dealing with, makes me wonder how my simple partial wiring harness replacement project could have turned into the protracted six month struggle that it has. I commend you on your excellent work! I'm guessing your signal lights will be working before mine. LOL.
Jim
Jim
#313
Thank you, Jim for the kind words. I hope when I remove it from the mock up to install it in the truck I have all the wires marked correctly. I still have to solder new wires into my turn signal switch. I'm using an old Guide turn signal switch that has a wheel that rolls on the steering wheel to cancel the signal. It has the old fabric covered wires that are pretty hard and brittle.
Thanks again, Mark
Thanks again, Mark
#314
After much head scratching and redesign, I think I finally have the wipers working the way I want them to. I ended up using the wiper motor and arms from my donor Mercedes. So, my wipers are now Mercedes Benz powered also, actually Bosch powered. I still need to remove the motor bracket to finish welding and to paint it. Once I get it bolted back in, I can install the wiring harness. Here are several of photos.
Everything clears the defrost duct nicely.
The motor bracket thru the radio hole.
I will use a mid 70s Ford truck wiper switch. The switch has wash function on it which I need for the windshield washer. It also has the same mounting threads and shaft diameter as the original wiper control, so I can use the original bezel and ****. I may upgrade later to an intermitent wiper switch from the same model Ford truck.
Thanks, Mark
Thanks, Mark
#315
I have the Guide 6004 turn signal switch rewired, painted and installed. I also made a mount and modified the can for the tach and painted it the same color as the turn signal switch.
This switch has a cancelling wheel that runs on the steering wheel. You can see it against the steering wheel in this pic.
I mounted an emergency flasher switch from my Mom and Dad's '66 Ford Ranchwagon on the column drop in the hole for the column shift tube. The E-flashers are powered hot all the time and the turn signals are powered thru the ignition switch. The turn signal switch doesn't have a provision for E-flashers, so I added the separate switch.
Thanks, Mark
Thanks, Mark
