1949 F4 V8 to Mercedes diesel build thread
I've been lurking here for a while so, I thought I would join in. I am a self employed Machine Shop owner/operator in north central Arkansas. I have been working on a '49 F4 build for a while to eventually use as my shop truck. My truck was a grain truck from Kansas with about 64000 miles on the odometer. The flathead v8 was seized from water in one cylinder. My original plan was to build a Mercury flathead to replace it but, I've changed course. I installed a '84 Mercedes 300 turbo diesel in its place. I have it mated to the original 4-speed. I've also installed a 3-speed brownie for the overdrive. I hope to get it on the road sometime this winter.
Mark
Mark
Brad, The engine I'm using is a 3.0 liter 5 cylinder turbo diesel. If I remember correctly it has 125HP and about 225ft lbs of torque. It is real similar to the '53 mercury v8 for power but at a higher rpm. I hope it will run good in the truck, it ran real strong in the car I took it out of. The Mercedes car weighs about as much as the truck.
Thanks for the welcome, Mark
Welcome to FTE. The larger trucks have a great appeal. Those of you that restore them have a lot of respect in my book.
mechmagcn is also from Arkansas and he has a Mercedes diesel in his truck and took it all over the country. His is a little F100 though.
https://www.ford-trucks.com/forums/1151782-how-far.html
Pictures, we love pictures!
Thank you for all the replies and hearty welcomes. I will try to post a few photos.
This is the engine adapted to the truck 4-speed. I used a stamped steel bellhousing for an H flathead 6 so I could cut and modify it. I machined an adapter for the crankshaft to use a 460 neutral balance flywheel. The starter is an FE series starter. I rotated the bellhousing slightly to raise the starter to the Mercedes starter position. The pan is too wide for it to be any lower.
Here is a view of the engine setting in the truck.
This is the crossmember for the Mercedes motor mounts.
Once I get everything connected the way I want it, I will pull the engine back out and clean it up and replace some of the gaskets and seals. I will also send the Mercedes flywheel and the Ford flywheels off and have them match balanced.
Thanks for looking, Mark
To answer a few questions. My auxiliary transmission is a Spicer 5531. I don't have any photos of the mounts for it , I will see if I can take some. I added another transmission crossmember and mount, from another truck frame I had, for the front mount on the Brownie. I made crossmember , that uses the front motor mounts for a flathead, for the rear of the transmission.
I am replacing the original T9 Warner 4-speed with a T98. I don't mind double clutching but as I get older my knee is acting up some so I thought it would be happier.
Thanks, Mark
Thanks, Mark
