1949 F4 V8 to Mercedes diesel build thread - Page 17 - Ford Truck Enthusiasts Forums
  #241
Old 11-19-2017, 10:06 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold
Thank you Scott. You take care of your back too. They don't get any better as we get older.
Mark
  #242
Old 11-20-2017, 07:10 AM
mechmagcn's Avatar
mechmagcn
mechmagcn is online now
Diesel Junky
mechmagcn is a name known to allmechmagcn is a name known to allmechmagcn is a name known to allmechmagcn is a name known to allmechmagcn is a name known to allmechmagcn is a name known to all
I think all of us guys that have done hard work can relate to the back problems. I have one scar on my back and need another, but I'm still going. Changed careers two years ago from heavy truck and equipment mechanic to maintenance supervisor at a small state park to try to relieve some of the pain. Keep on working on that rig as you feel like it, it'll be waiting on you when you don't.
  #243
Old 11-21-2017, 01:15 PM
49fordv8f4's Avatar
49fordv8f4
Thanks for the reply, Jeff. I will keep plugging along at it as I can. It's not going anywhere. If you ever get up this way, stop in!
Mark
  #244
Old 11-21-2017, 01:21 PM
49fordv8f4's Avatar
49fordv8f4
A small update. My friend dropped off the panels above and below he grill. Now as soon as I get the grill powder coated I can install the grill. Then assemble the fenders when he gets them finished.
Mark
  #245
Old 11-21-2017, 10:05 PM
52 USCG Panel's Avatar
52 USCG Panel
52 USCG Panel is online now
52 USCG Panel is a name known to all52 USCG Panel is a name known to all52 USCG Panel is a name known to all52 USCG Panel is a name known to all52 USCG Panel is a name known to all52 USCG Panel is a name known to all
That's looking good, Mark. Shiny parts are motivators. How did you attach your FORD letters? We've had discussions about how some of our members have done it. The first time, I used the little single use press-on backers that came with the letters. At least one of the letters wasn't quite tight, and in just a short time started to damage the paint. The second time, I glued my letters on with 3M 5200. There is no movement this time. Removal may be difficult, but getting the little backers off was not easy either.
Jim
  #246
Old 11-22-2017, 11:31 AM
49fordv8f4's Avatar
49fordv8f4
Mine has these screws and straps. Are the later ones different?
Jim, I just have the letters setting in the holes. I'm using the letters that came on the truck originally. They are not perfect, but I think they will look fine.
Thanks, Mark
  #247
Old 11-22-2017, 11:38 AM
49fordv8f4's Avatar
49fordv8f4
Thanks to Bob, bobj49f2, for the measurements, I was able to drill my grill for the stainless steel strips that my son gave me for Christmas a couple of years ago. Since I'm not man enough to hand crank the diesel, he got me the set without the crank hole.
Thanks again,
Mark
  #248
Old 11-22-2017, 12:40 PM
52 USCG Panel
Mark, what you have for fastening your letters looks great. I bought replacement letters, and as mentioned, they came with single use press-on backers. Getting the backers on tight enough to prevent movement was hit or miss and removing them was a royal pain. Your original letters should work out fine for you. I kept mine, but they are much more pitted than yours.
Jim
  #249
Old 12-13-2017, 05:21 PM
49fordv8f4's Avatar
49fordv8f4
This grey matches the original color of the hinges pretty closely.
I picked up my running boards and hood hinges at the powder coater today. I had the running boards done in the same hammered black as my bed. It is a little thicker than gloss black and hides a few of the blemishes. My running boards like my bed aren't perfect. I think they turned out good.
Thanks, Mark
  #250
Old 12-13-2017, 05:58 PM
Mixer man's Avatar
Mixer man
Mixer man is offline
Journeyman Apprentice
Mixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud ofMixer man has much to be proud of
Looks perfect to me. I like that hammered finish.
  #251
Old 12-13-2017, 06:52 PM
49fordv8f4's Avatar
49fordv8f4
Thanks Bob. I set them in place on the truck and they do look good.
Mark
  #252
Old 12-13-2017, 07:23 PM
raytasch's Avatar
raytasch
raytasch is offline
Old guy with old toys
raytasch has a superb reputationraytasch has a superb reputationraytasch has a superb reputationraytasch has a superb reputationraytasch has a superb reputationraytasch has a superb reputationraytasch has a superb reputationraytasch has a superb reputationraytasch has a superb reputationraytasch has a superb reputationraytasch has a superb reputation
Mark
We need picture proof of how good they look, Mark. Let us be the judge.
JK, but you know that.
  #253
Old 12-13-2017, 08:09 PM
49fordv8f4's Avatar
49fordv8f4
Thanks, Ray. Hopefully Saturday I can back it out of the shed and get some pics.
Mark
  #254
Old 12-23-2017, 12:50 PM
49fordv8f4's Avatar
49fordv8f4
The dark spot on the door is a spot inside the lense of my camera.
Here is a photo of the running board on the truck. I still haven't had a chance to bolt the running boards on and pull the truck out of the shed to take a photo. I also got my grill back from the powder coater and installed the strips.
Thanks, Mark
  #255
Old 12-23-2017, 11:06 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
Scotty's 52 F3 is online now
Scotty's 52 F3 has a great reputation on FTE.Scotty's 52 F3 has a great reputation on FTE.Scotty's 52 F3 has a great reputation on FTE.Scotty's 52 F3 has a great reputation on FTE.Scotty's 52 F3 has a great reputation on FTE.
Lookin good!
Quick Reply: 1949 F4 V8 to Mercedes diesel build thread
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
