What Clutch set use and what else to do?
Old 10-29-2014, 11:38 PM
Boss08v10's Avatar
Boss08v10
Boss08v10 is offline
Going to put a clutch in the 94 F150 4.9 with the mazda 5 speed trans. Looking for input on what to buy, from where and what else to do while we have it apart. Truck has about 140,000 miles. There so many different kits on ebay that it is over whelming to choose.
Many come with a new slave cylinder, is this necessary? Should we get a new pressure plate or have ours resurfaced? Organic of other clutch disk.
Running 4.10 gears with 33" BFG mud terrains.
Whats the good word here and thanks.
On a side note, found a brand new front bumper and grill insert today that was taken off when new back in 94, stored inside. Got for a $100. CL rules sometimes. Will add picks soon
Old 10-30-2014, 09:35 AM
garthneddy's Avatar
garthneddy
garthneddy is offline
I've always had good luck with Zooms 30000 series clutch kits. They've held up fine in everything from DDs to wheeling rigs with FEs and 38s.
I'd recommend getting a genuine Motorcraft slave cylinder, the auto parts store house brands don't have nearly the same quality.
Old 10-30-2014, 11:19 AM
Freightrain's Avatar
Freightrain
Freightrain is offline
Replace it all, including slave cylinder(if not and it fails you have to pull it all apart again). Surface flywheel and get new pilot bearing.
As for which clutch? For general all around use, I would get a LUK stock replacement. They make them for OEM, so it is good quality. Many kits come with throw out bearing and some even pilot bearing. Don't skimp.
GravyCrockett
02-02-2018 08:43 AM
nordictom
10-02-2015 09:46 AM
flat4vw
01-16-2008 08:54 PM
Pnutman
1983 - 2012 Ranger & B-Series
05-14-2005 01:10 AM
92f150I6
18
03-30-2003 06:25 PM
Quick Reply: What Clutch set use and what else to do?
