1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
NAPA or OEM hydroboost unit?
Old 07-30-2014, 03:21 PM
airjeff's Avatar
airjeff
airjeff is offline
I noticed over the weekend that my hydroboost unit is starting to leak. I looked at Tousley and NAPA and NAPA is around $200 cheaper. Is there any reason not to go with NAPA? I want a good quality pump that will last, but I'd like to save $$ if there is no difference.
Old 07-30-2014, 03:56 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Check the hoses and all the connections.
There have been reports of the fittings
leaking because they have worked loose.
Sean
Old 07-31-2014, 09:32 AM
airjeff's Avatar
airjeff
airjeff is offline
Good to know, I'll double check today. But I'm pretty sure its leaking out the weep hole at the bottom so I think I have seals going bad. Also, since I picked up the Ex 3.5 years ago the brake movement has been slow/spongy up and down so I think there is something wrong with the booster. (brake system has been completely bleed 4 times)
Anyway, if anyone knows good or bad about the NAPA unit let me know. I'm inclined to save some money, but NAPA parts let me down multiple times on my last brake job so I'm a little hesitant now.
Old 07-31-2014, 02:58 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
You could give the people over at Read Head Steering a call
and ask who they recommend for a unit.
I think they may have a good idea because the systems
are sorted connected. At least they could tell you who
makes the ones that cause the most grief for the steering
system. Worth a try.
Sean
Old 07-31-2014, 04:45 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
Avoid NAPA and go OEM. NAPA uses cardone and re-boxes it. Cardone parts are very hit or miss and the quality is not there since they are cheap re-man parts. I wouldn't trust my brakes to a Cardone hydro boost
MR Smitty
08-25-2015 03:32 AM
cabloom300
10-01-2013 07:16 PM
michaelshewkin
07-04-2010 06:48 PM
lizardman1
05-12-2010 07:46 PM
Mach1
07-23-2007 09:33 AM
Quick Reply: NAPA or OEM hydroboost unit?
