Oasis Request & question on '08 F150
Hi
I'm looking at buying a 2008 Lariat screw with 80K on it at Buick dealer. I was wondering if someone could run me an oasis report on it. I posted the vin # below. Any help would be greatly appreciated. I'm replacing my '98 Expy with the 5.4 2v motor that has 210K of flawless miles. I'm curious about the cam phaser, spark plug & exhaust manifold problems have read about on the threads. I'm wondering if these problems were fixed by the '08 MY. I know anything can happen, but it seems like there are really any posts on those problems for the '08's. Any opinions would be appreacited.
vin #1FTPW14588FB55655
So yesterday I took this '08 truck to a friend's shop to put it on a lift and give it a final inspection before making the deal. As I pulled into his lot the truck starting shaking like it was going to stall and making a crazy racket like a rough running diesel. So we were convinced the cam phasers are shot. The thing was making such a terrible noise he said to hurry and get it back to the dealer before it died. I couldn't get a good look at the engine build date but the truck build was march '08. On teh way back it started running terrible at idle and threw a check engine light. So needless to say I ran away from the deal as fast as I could.
Thanks for the info guys I do appreciate it.
Sent from my XT1080 using IB AutoGroup
BTW, here is every option that particular truck was equipped with from the factory:
Primary FeaturesBuild Date:**09.03.2008Vehicle Line:**F150Body Style:**Double Cab (3/4 Door)Version:**150Engine:**5.4L 3V V8Transmission:**4 Speed Automatic 4R75E LivoniaDrive:**LHD 4WD (PTD)Axle Ratio:**3.73Emission:**With California/Green State ReqAir Conditioning:**Automatic Air ConditioningPaint:**Ebony (Solid C/C)
?dd32
Minor Features
*Ebony Interior*Imola*Front Door Scuff Plates*Less Cargo Stowage Device*Stone Cuffs-Front MIC Black*With Rear Mic Black Stone Cuffs*Less Load Bars*Less Bed Divider*Less Front Load Bar*Decal - 4X4 Pueblo Gold*With 5.5' Styleside Box*Less Pickup Side Rails*With Pick-Up Tie Hook - Inner*Less Pickup Box Extender*With Base Payload Package*139"/3531MM Wheelbase*Lariat/Luxury Version-LT. TRK*(-) Version Packages*Dearborn Plant Build*Less Special Equipment Package*Lariat - Sales Badge*With Power Equipment Group*With Memory Pack*Feature Content Group 1*With On-Board Diagnostic System*"US" Tailgate Badge*With English Language Label*Owner Hand Book Pack*With Power Front Windows*With Electric Rear Quarter Window*With Privacy Glass*With Power Sliding Rear Window*Less Heated Rear Window*With Mini Overhead Console*Flow Through Console With Armrest*Adjustable Accl/Brake Foot Pedals*Front Carpet/Rubber Floor Mats*Rear Carpet/Rubber Floor Mats*With Carpet Floor Covering*With Illuminated Sunvisor - Drivers*With Illuminated Sunvisor-Passenger*Less Load Area Cover*Running Board - Eliptical Chrome*With Bright Front Grille*With Bodycolour Wheel Lip Moulding*With Electrochromic R/View Mirror*Drivers Power Fld/Htd W/Puddle Lamp*Passenger Pwr Fld/Htd W/Puddle Lamp*With Black Exterior Mirror*With Signal Mirror System*Less Adhesive Mirror Backing*With LH Manual Lumbar Support*With RH Manual Lumbar Support*With Drivers Heated Seat*With Heated Passenger Seat*2 Row-H/Ser Flip Up W/Elon Cushion*With 2nd Row Folding Armrests*With Driver 6 Way Pwr.Seat Adjuster*With Pass 6 Way Power Seat Adjuster*With Heavy Duty Trailer Towing*With Front Towing Hook*Exterior Door Handle - Black*Double Cab (3/4 Door)*With Central Locking System*With Door Entry Remote Control Unit*With Keyless Entry System*Power Tilt/Slide Sun Roof*Moonroof Sw Open/Close One Touch*Less Tu-Tone Accent Colour*Less Body Tu-Tone Paint*Less Bodyside Accent Stripe*Fr Bumper Chromed With Lower Grille*Rear Bumper - Steel Step - Chromed*With Front Licence Plate Bracket*With Driver Air Bag*With Passenger Air Bag*With 18" Steel Spare Wheel*Tyre Pressure Sensors - 315 MHZ*H/D Dual Front Shock Absorbers*Heavy Duty Rear Shock Absorbers*With 20" X 8.5 Aluminium Wheel*P275/55R20 A/T OWL Tyre*Spare Tyre - LT275/65R18 A/T OWL*Market Road Condition - General*With Super Engine Cooling System*Less Immersion Heater*With California/Green State Req*3.73*Less Rear Axle Limited Slip Diff*With 9.75" Axle*5.4L 3V V8*Single Exhaust*Less Exhaust Pipe Extension*With 4 Wheel Disc-Brake*4 Wheel Anti-Lock Braking System*Less Anti-Spin Traction System*Normal Fuel Fill*Less Floor Mats-FIA*Less Remote Starter - FIA*Heavy Duty Aux Trans Oil Cooler*Electric Trans Case With IWE'S*Less Skid Plates*With Single Fuel Tank*Non Locking Fuel Cap With BP Label*For Unleaded Fuel*Colour Keyed Steering Wheel*With Speed Control*Redundant Controls - Steering Wheel*With MPH/KMH Speedometer*With Tachometer*With Compass/Thermometer In Cluster*With Message Centre*With Reverse Proximity Sensor*Standard Duty Battery*AM/FM Str/CD/Clk/Navig System*With Satellite Radio Reception*With NAAO Radio Frequency*Less DVD Player*With Radio Subwoofer*Less Camera*Less Specialty Packages*Less Daytime Running Lamps*With Bright Headlamps*With Front Fog Lamps*With Illuminated Entry*Tail lamps - Level 1*With Automatic Headlamp On/Off*Ebony (Solid C/C)*Generic Country Group 1*Vermont Vehicle Reg Code Label*150 Series*4L34 5310 UA Left Front Coil*4L34 5310 UA Right Front Coil*6L34 5560 ME Left Rear Leaf*6L34 5560 ME Right Rear Leaf*Less B & A Control Codes (9270)*4 Speed Automatic 4R75E Livonia*F150*(+)"USA"*(-)"N"*(-) GVMT Service Administration*(-)"CDN"*(-)"GU"*(-)"BRN"*(-)"BZ"*(-)"IS"*(-)"ATG"*(-)"NCL"*(-)"AW"*Less Fleet
?dd32
Minor Features
