1970 F250 4X4 Rebuild
#211
#212
#214
Are those 2 1/2" wide leaf springs? I went through that whole hanger swapping and all on my f250 4x4 with a short bed you got to watch how far back you move the hangers or you will run out of frame rail since it's shorter then a long bed. Now I got to redo my rear suspension all over since I lifted the front more. I have zero complaints about that floor jack I'll gladly buy another one at a 3rd I the cost of a "quality name brand" one.
#215
Crazed, I shop there all the time. The key is just remember what you are doing and look at what is there. I bought my sandblasting cabinet from HF, my portable 40lb sandblaster, engine crane, gantry crane, engine stand and many hand tools. I am the first one to say I love all my Craftsman Tools, but HF has a lot to offer.
#216
#217
#218
#219
Once I had the front springs out I was able to look at the replacement bushings I have. They are from Energy Suspensions and the entire old bushing has to be removed including the thin outer shell. I was able to get one of the old bushings removed and left the shell in and the new bushings will not fit, not even close. I only lost the one bolt as all the others loosened and slid out without trouble. I am going to build a new front spring mount that is stronger and has a receiver built in. Might attach a couple of rings for tow points.
#220
#221
That will get done later. I have the following things to get done,
1) Remove the transfer case.
2) Finish mocking up rear suspension.
3) Weld up Old Rear Suspension holes.
4) Mount 1979 Power Steering Box.
5) Replace Frame cross supports that are thin from rust.
6) Sandblast Frame and paint.
7) Then comes the fun part of re-assembly of the frame some the cab can come back in to be worked on.
#222
#223
Of course check the pattern to make sure. Gears are a lot easier to manufacture in bulk and once they cool being the same. Not so much so with cast iron carriers or housings.
#224
Thanks JEFFFAFA, as always great input. The 4x4 axle has some deep rust on the axle tubes where the lower U-Bolt supports have been since 1970. I am thinking about changing to the 2 wheel drive set-up that flips the U-Bolts around so the ends point up.
Lower right corner you can see the U-Bolt pointing down.
U-Bolt Support on the 4x4.
2 Wheel drive U-Bolt set-up.
#225
