The old P0670 P0683
The old P0670 P0683
Friend of mine picked up a 2002 7.3 CC LB F250. He suddenly got the the check engine light and when we scanned for codes we got the P0670 and the P0683.
We did some research and everything points to the GPCM since this is a California vehicle.
Since my Ex is the same year we decided to swap the GPCM's between trucks but the SES light did not go out.
My Questions....
1. should we have driven the truck for a certain amount of time after the swap for the SES light to go out?
2. Do we need to clear the codes after the swap then drive it around to see if the light comes back on?
We didn't have enought time to drive it around after the swap but left it running for a bit to see if it would go out.
Tim M
My Questions....
Tim M
There is most probably a circuit problem and not a mechanical issue. Somewhere along the circuit it is open or has increased resistance and the PCM is reporting that as out of range.
Try removing the PCM Harness and cleaning it with CONTACT CLEANER and do the same at every point up to and including the GPM.
In the process, you can use a VOM to check the continuity of the circuit.
Update....
We swapped the GPCM and cleared the codes and he drove it around up to today without the engine light coming on.
He was able to get his smog check done so he will return my GPCM and pick up a new one for himself.
Lesson learned ...clear the codes or disconnect the batteries. I won't assume the code will clear up on its own next time.
Thanks guys.
Tim M
Thanks guys.
Tim M
Update....
Thanks guys.
Tim M
Thanks guys.
Tim M
FSFT
6.7L Power Stroke Diesel
11-20-2018 10:09 AM
heathdenson
06-14-2015 12:04 AM
RT4957
02-19-2005 09:46 PM
